diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
Whats the cheapest Route OHP + panel or complete DIY? - Click HERE for Original Thread
Synapses
Im just asking for personal experiences really. I am wanting to use a 7" LCD for my projector (lilliput) or a seform one ( $145 for VGA version) although i dont know if the seform one will work :S
But anyway, I have £166 to spend at the moment. Am i best getting an OHP and a panel? The OHP would opbviously need good amount of lumens. Or should i get an ATX case etc with MH setup/triplet lens?
Remember im on a £166 limit at the moment.
Thanks, any replys with your info is appreciated. :angel:
wylie-c
Well, the ohp route is the easiest, for sure. I am using a 7" non-vga ( 480x234 composite ) lcd on a 3M 1730. It uses a 360 watt halogen, and considering it was simple and cheap, I am totally satisfied with my results. I am projecting at 8' diagonal, or close to 100".
Link to picture of 100 inch from my 7" lcd is attached.PIC
Iron Man
Personally i think DIY is usually going to be cheaper . But it depends on if you want to price your time or not
Synapses
Hi, Yeah i was thinking i dont really need the vga version, its a fair bit more an i already have a vga to TV converter. Your results are pretty good! Im not going 100" more like 70" - 80"
partyharty
The overhead projector/panel route would be cheapest IF you can look around and find a overhead projector around where you live. You can usually pick them up at garage sales (I purchase 2 at them) as well as college sales, Sate sales, and auctions. If you purchase one close by like that you usually will not pay much for them (I have not paid over $25 for a overhead yet and I have purchased 4). You can get them on ebay but shipping will kill ya.
A panel can be had fairly cheap on ebay (but you have to sit back and watch as some people are wanting $$$$$$ for what amounts to junk). Make sure you know the specs of the panel (not what they say in the ad because the sellers are often wrong).
Chris
wylie-c
If you intend to display a computer desktop, the non-vga will be quite blurry. But if you're only concern is to watch movies it will work just fine. The vga will still have a better picture, but it's up to you whether or not it's worthwhile. Another consideration for you, a DIY setup w/ a metal halide will have way better bulb life ( 20,000 hrs, avg. ) than a typical ohp's halogen ( 150ish ). Next time around, I will build my own, but for a first time go at it just to see how it would look I went with the ohp. I was too impatient to build anything, It took 5 min's to strip the lcd and place it on top and turn it on.
Page generated in 0.024528980255127 seconds with 17 queries,
spending 0.00755644 doing MySQL queries and 0.01697254 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
