diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
guys I really need some help - Click HERE for Original Thread
blackie
Hi guys this is the thing a got a Sayett MediaShow Projector
I got it for our church to watch christan movies and the thing is I can't get it to work with pc
I know it must need drivers but Sayett went out
but is there another driver or software i could use to reconise the projector
It uses Sayett MediaShow 2.3
all help is needed we are a small church not alot of funds and those folks
really would enjoy watching it on big screen I have looked the internet over
I told them at church those guys on DIY will know just what to do
so come on guys help me out if you can
thanks Blackie:angel:
partyharty
I dont really know much about that projector but I will tell you some things to check out (troubleshoot).
I am assuming this projector has a VGA input and it does not require a special adapter. If so turn it on and see if there is a "test" screen. If so then attach the computer and setup the computer at the lowest resolution (usually 640x480 60hz with 16 color. If it works simply start bumping up the colors and resolution until you get to the highest it supports.
If you can give more information about it that would be great. Model #, what happens when you turn it on (does it come on or does it not?), What have you tried to "fix" it (so we know what to tell you to try). What inputs does the projector have? Does it have (or come with) a remote.
It could be something as simple as a dead bulb, need to switch inputs with the remote, or it could be something as complex as a dead projector :< Without more info it is almost impossible to tell.
Chris
partyharty
it might also be helpful to know if you have the origional (OEM) cables (power adapter, input cable, etc) or not.
blackie
Hi guys it does work when it come on it shows
Sayett Mediashow v2.3
on setup you can have front or rear projection
then it has erase current adjustments when you press that it says no source connented
then it's got erase all justments
then exit
the color bars are great color
now the connentions are
1 video input looks like 15 pin female
2 vga monitor =15 female
3 mac monitor =15 female
4 ega/cga monitor=9 female
I have it hooked up to the vga monitor to my pc monitor
blackie
partyharty
so it sounds to be more of a connection issue instead of a projector issue.
According to the posts when I googled it this projector does 640x480 (someone jump in and correct me if I am wrong). so make sure your computer is set to 640x480 (if it is xp then you will have to (right click on desktop, settings tab, click on advance button, Adapter tab, list all modes and select 640x480 16 color there).
Other than that it could be the cable problems. To answer your first post most projectors and projector panels do not need drivers as they are seen as a monitor (and thus use the standard monitor driver).
Chris
partyharty
Forgot one last thing. You may need to select what source you are inputting to (so look around for a button or a menu item that says source and make sure it is set for VGA in).
blackie
Do you mean on the projector or pc
the cord is new i just got it
thanks dude
with you guys helping this thing will be up and running soon
thanks:D
p.s
on the front it does have what looks like a senor for remote
partyharty
on the projector. You are basically needing to tell the projector , guess what this is where the signal is coming from,
unfortunatly you may need the remote to do so (or then again you may not?) Like I said I am not that knowledgable with this particular projector.
Chris
blackie
Sayett Mediashow remote control is my quest now, you really are great for this forum dude you really helped me out and the people at my church thanks you
Blackie:clown: :angel:
partyharty
No problem. Hope you get it all worked out
Chris
blackie
ViewFrame Spectra LCD Projection Panel FOR SALE
Just make offer it has case. power cord and remote thats it
it just could'nt work it it has composit input i could see my dvd screensaver and hooked up pc could see win,
but it rolled
blackie
oh buyer pays shipping and i want cheat on shipping lol:smash:
partyharty
! ! ! SOLD ! ! !
Page generated in 0.040189027786255 seconds with 16 queries,
spending 0.01507735 doing MySQL queries and 0.02511168 doing PHP things.
Copyright ©1999-2009 diyAudio.com
