| glennb |
I have some doubts in my mind about the input impedance of a common non-inverting op amp circuit which appears in the data sheet for the LM4780 chip amp, and my research has not revealed a definitive answer.
Here's a couple of simple questions for which I am seeking the correct answer, and why:
1. What is the AC input impedance of the circuit below, for frequencies above the f3 point determined in part by Cin ?
2. What value should RB actually be to balance the DC input offset currents, so that the output DC offset is minimised?
Please reply if you know the correct answer. I would prefer not to waste bandwidth with any off-the-top-of-my-head guesses. |
| Ouroboros |
DC offset is caused by other things as well as by the PD due to input currents!
But to answer your question, 14K for Rb is about right (20k in parallel with 48k). But frankly, unless your input bias currents are high, I wouldn't have though it will make much difference.
But why is this an inverting amp when you call it non-inverting? |
| Ouroboros |
| Oh, and your input impedance will be about 980 Ohms in the audio range. |
| peranders |
Glenn, first I think you should take a close look at the datasheet of LM4780 and also AN-1192 and also application notes for the LM4780.
The 47 k is totally unnecessary. If you want to do it really right the 953 ohms resistors should be 20 kohms if you want to minimize the offset voltage. This resistor had also a purpose of protection during power down and the recommend value was 1 kohms.
The input impedance = Rin => 1 kohms in your case => the input cap is way too small. 10 uF at least should it be. f = 1 /(2*pi*R*C)
EDIT: I have checked the datasheet and I see that you have taken the exact circuit as suggested but something is wrong, according to me. Am I wrong? |
| glennb |
Whoops, I actually meant an inverting amp circuit. My apologies.
The wikipedia says Zin = Rin for the inverting amp, as does every other reference I could find. In which case, Cin = 1 uF is indeed way too small for this circuit as audio amplifier:
f3 = 1 / ( 2 . pi . C . Rin || Ri ) = 163 Hz (no bass!)
(where Rin || Ri = 979 ohms)
Also, RB should really be Rf || ( Ri + Rin) = 14118 ohms, rather than the Rf || Ri = 953 ohms given in the circuit.
Does anyone think that NS stuffed up these two aspects of this particular app circuit for the LM4780? |
| Ouroboros |
| 953 Ohms would be correct if you didn't have the input capacitor or course. |
| peranders |
| quote: | Originally posted by glennb
Does anyone think that NS stuffed up these two aspects of this particular app circuit for the LM4780? | I think NS has done a little too much copy and pasting I'm afraid. |
| glennb |
| quote: | Originally posted by Ouroboros
Yes, because then Ri would be DC coupled to a low source resistance to ground, which is the general assumption made for calcuating RB = Ri || Rf in a classic inverting opamp circuit. I think NS failed to realise that adding Cin actually changes the DC considerations around the opamp inverting input. |
| glennb |
| quote: | Originally posted by peranders
...The 47 k is totally unnecessary.... |
Yes, without the 47K there is still a DC charge path for Cin, which is through Ri and Rf.
The resistive load on the input which determines the f3 then becomes Ri alone, ie.
f3 = 1 / ( 2 . pi . Ri . C )
It then follows that RB = Rf, as there is now no DC path through Ri.
My beef with the inverting circuit is that to have a reasonable input impedance (say >20K) and a resonable gain (say 20) requires Ri = 20K and Rf = 400K. In my mind, 400K is too large for a feedback resistor. The overall noise would be higher and the DC offset input currents would make the DC output offset voltage much higher.
..I have checked the datasheet and I see that you have taken the exact circuit as suggested but something is wrong, according to me. Am I wrong? |
I cut/paste the application circuit from the LM4780 PDF, wiped out the power supply connections, and moved the Rf label from below the resistor to above. |
| Ouroboros |
Has anyone measured the distortion of a 3875 (or similar) in inverting and non-inverting modes. Or can tell if they sound any different?
Many ordinary op-amps measure better in an inverting mode as the elimination of the common-mode signal keeps the input stage operating in a more linear region. I guess the same is likely to be true for power op-amps, although an inverting mode will need an input buffer stage to drive the relatively low-Z input of the inverting power stage. |
| moamps |
The 47 k is totally unnecessary. | Hi,
placing resistor in input of inv. opamp is good for stability. If input isn't pulled to ground (thru source impedance) for any reason (bad input switch, pot or in experimental phase), inv. opamp will oscilate. My simple idea is placing same value like RF (20 or 22k here).
Regards |
| peranders |
| Ok, totally right if you have the amp has the input unconnected but the gain will be much less than 10, in fact 0.5 only. Isn't this reasons for instablility? I haven't tested this. |
| moamps |
From my experience, LM xxxx amps will start to oscillate if gain is below 1 what is also depending of PCB or P2P design. If gain is below 10 or so, opamp will be temporary unstable (in one part of output signal-waveform ) but not all the time.
NS datasheet isn't correct, IMHO. (obviously copy/paste errors)
Regards |
| carlosfm |
If you want to do it really right the 953 ohms resistors should be 20 kohms if you want to minimize the offset voltage. |
:eek:
Rb is fine.
It should be Ri//Rf.
If you want to minimize DC.;) |
| glennb |
| quote: | Originally posted by moamps
Hi, placing resistor in input of inv. opamp is good for stability. If input isn't pulled to ground (thru source impedance) for any reason (bad input switch, pot or in experimental phase), inv. opamp will oscilate. My simple idea is placing same value like RF (20 or 22k here). |
The LM4780 data sheet also contains the following circuit snippet, indicating that a resistor to ground (from the Ci2 Ri2 junction) is not really necessary.
They way I see it, the - input is pulled to ground (ie. a DC path to ground) by Rf. The + input is pulled to ground by RB, and by definition the + and - inputs are at the same potential, so the - input will therefore be at ground. Any comments? |
| glennb |
There will be no "gain" delivered through the effective 47K + 1K input resistance (to give your overall 0.5 gain = 20K / (47K+1K) )because the input end of the 47K is grounded !!!!
I don't think the stability is affected between having the 47K there and simply removing it. |
| mhennessy |
That's correct. And to complete the picture, consider that, if you like, the op-amp output will "move" to ensure that there is always 0V at the inverting input. An input signal will attempt to pull the - input one way, and the output swings the other way to pull the input back to zero.
When analysing this configuration, it helps to consider the currents in the two resistors ;)
Mark ;) |
| moamps |
The LM4780 data sheet also contains the following circuit snippet, indicating that a resistor to ground (from the Ci2 Ri2 junction) is not really necessary. | Hi,
look at picture below, you will find RIN1 act like this resistor.
We talk here about AC gain, not DC.
Regards |
| glennb |
Hi, look at picture below, you will find RIN1 act like this resistor.
We talk here about AC gain, not DC. |
Cin1 & Rin1 are isolated from interacting with Cin2 & Rin2 because the Audio Input A is driven by an AC low impedance source, and DC can't flow around them because there are two caps in the way.
Therefore the 47K at Rin1 does not influence the AC gain, DC operation point or stabilisation of op amp B and its associated components Ci2, Ri2, RB2, Rf2. |
| glennb |
| quote: | Originally posted by mhennessy
That's correct. And to complete the picture, consider that, if you like, the op-amp output will "move" to ensure that there is always 0V at the inverting input. An input signal will attempt to pull the - input one way, and the output swings the other way to pull the input back to zero. |
Yes. Let's remove the 47K Rin from the circuit in the very first posting. Say if a DC offset appears on the input socket (faulty preamp or whatever), the input cap Cin charges up through Ri, and the charge current is precisely balanced by the opamp output pumping a current through Rf. The - input remains at ground potential and no current flows into or out of it, except its normally minute input offset current.
However, if the incoming DC offset offset voltage is very high ( > Ri / Rf * MaxOpampOutputVoltageSwing ), the op amp won't be able to keep up with it, and the - input will swing above ground for a while until the cap is charged up. This is not so bad if Rb is present and the - / + inputs have a pair of reversed diodes across them on the chip, but it could destroy the opamp if they aren't there. This same risk applies to nearly all cap input coupled opamp circuits. |
| moamps |
Cin1 & Rin1 are isolated from interacting with Cin2 & Rin2 because the Audio Input A is driven by an AC low impedance source.......Therefore the 47K at Rin1 does not influence the AC gain....... | Hi,
if source isn't connected (my post 12), Rin1 has influence on gain (loop gain) of second opamp (-RF2/(Rin1+Rin2)) If this loop gain is too small, opamp will oscillate.
Regards |
| mhennessy |
Yes - this is a very good reason to include RB. Also, it helps protect the chip during power-up/down, and also during massive input signals that drive the op-amp into clipping.
I remember being quite astounded that most people omitted the resistor when inverting GainClones were all the rage last year :dunno:
Mark ;) |
| carlosfm |
I've always used a multi-turn pot instead of Rb to adjust DC.
On some cases I removed the MT-pots and replaced by a resistor of the value the pot was measuring (which BTW was never the same value on both channels).
Anyway, I'm not so sure about this NI movement...
I've done almost everything with GCs (IGC, NIGC, BIGC, BNIGC), and the best sound I have is my BIGC power amp (with OPA627), and that's why I have this one on my main system.:cool: |
| glennb |
Hi, if source isn't connected (my post 12), Rin1 has influence on gain (loop gain) of second opamp (-RF2/(Rin1+Rin2)) If this loop gain is too small, opamp will oscillate.
Regards |
OK, I missed the bit about 'source not connected'. |
