diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
Unstable picture from AV-in... I need help - Click HERE for Original Thread
HouseMachine
Finally I have stripped a PsOne lcd and everthing is ok except av-in function. Picture is not stable, I mean there is fluctuation on the picture. Also, signal is coming intermittently...
I have looked all the topics that related with Psone lcd but I couldn' t find any info about this issue.
I' m using a noname 7.5volt 300ma ( 3 amps ) adaptor, do you think this is an adaptor issue ?
HouseMachine
ok guys I found some info in ace's psone thread. probably an adaptor issue..
bobharry
Yeah it will be an adapter issue, just so you know for the future 300ma is .3amps and 3 amps is 3000ma;).
HouseMachine
whaaaaatttttttttttttttttttttttt :eeeeeeeek:
bobharry thanks billion times you saved my life ( psone lcd : ) , I was going to break lcd screen just before your message :)...... I was so mad because of this issue.
I am total idiotos because I was thinking 300ma is 3a :smash: .... I will get an original psone lcd adapter immidiately.
And I thought I am not a diy guy, I don' t even now about electric ... :mad:
bobharry
Thanks appreciated, anyway you'll learn about electronics after time, like I am doing. I don't really consider myself much of a diy guy either, I can't even undo a screw properly if it has too much resistance:o.
Page generated in 0.021531105041504 seconds with 16 queries,
spending 0.00917888 doing MySQL queries and 0.01235223 doing PHP things.
Copyright ©1999-2009 diyAudio.com
