| dok33 |
| I'm looking for the Thiele/Small Parameters for a round 12" Kicker Solobaric 2ohm sub. I can't find them online so any info would be greatly appreciated! |
| Rosu99 |
Hi, I got the parameters on my computer, it´s the 2 ohm 12" round kicker solobaric:
Manufacturer: kicker
Model: solo12
Filename: SOLO12_2.UNT
Speaker type: Bass
Sd: 511.00 cm^2
Vas: 146.00 l
Cms: 3.99e-04 m/N
Cas: 1.04e-06 m^5/N
Mmd: 140.35 g
Mms: 146.88 g
Rms: 2.30 Ns/m
Fs: 20.8 Hz
Bl: 10.75 N/A
Re: 1.75 ohm
Le: 0.00 mH
Qms: 8.32
Qes: 0.29
Qts: 0.28
Pmax: 600.0 W
Xmax: 8.51 mm
and if you dont know..
use only sealed boxes for this sub,
else it will be damaged..:xeye: |
