diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Loudspeakers
phase & Bi-polar caps - Click HERE for Original Thread
PeteMcK
Dumb Q., but how do bi-polar caps affect the phase of a signal?
I remember it's possible to make a bi-polar by putting two polarised electros in series, but with the same two poles (say+) connected together; are commerical bi-polars just the same thing in a single package?
cheers,
Pete McK
Ouroboros
The phase shift will be the same as with any other cap of the same value.
Commercial bipolar electrolytics are formed so that there is an insulating interface layer between the foil and the electrolyte on both foil surfaces. The effect is indeed similar to two series-connected back-to-back electrolytics.
The problems with bipolar electrolytics are that the tolerance is poor, (and can vary as they get old), and that leakage can be high, although that is not usually an issue in crossover networks.
Page generated in 0.016519069671631 seconds with 16 queries,
spending 0.00849342 doing MySQL queries and 0.00802565 doing PHP things.
Please support our sponsor.
