| AudioGeek |
ok,
yeah I know I am in the process of a Jordan JX92s bipole. But, I am looking at some others including Fostex.
I do have power (>15W tube).
Out of all the Fostex drivers and Jordans... which should I go for???
>95db eff is not really what I am looking for.
decent bass (down to 70Hz at least), flat response and NON droopy highs.
I don't really want to go to horn loading.
So, sealed or BR.
Thanks!! |
| GrahamnDodder |
If you want a wide sweet spot, you might want to go with a double bass reflex using a Fostex FE127E driver. Only about $37, and will meet your bass criteria (down to the 50's in a DBR enclosure.)
The cone, at 4.5", is small enough not to beam the highs (or need a whizzer like the 206's.)
GnD |
| AudioGeek |
how about the FE207E?
OR the Jordans? |
| planet10 |
There are just too many good choices (which is why Full-rangers tend to have more than one set of speakers :))
nothing wrong with the JX92 bipole
FX200 is another one to consider...
and Visaton B200
and FE167 in BoB Brine's ML-TL
or bipole FE103 (actually bipole any of these :))
and i could go on...and on ... and on...
dave
planet10/currently listening to a set of 8" refugees from Capital Iron ($20 invetsed)... |
