diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
Any one know of a .. - Click HERE for Original Thread
JasonL
Hey there all im seeking yet another Subwoofer. i have a 15" usd sub now ( Car audio subwoofer good driver..) i am looking for a good hi excersion 10" driver any one know of one i have the power to power it but my goal is to have a ported box with a 10" 4 or 8 ohm will work..
Jason
have a look at my usd that i have now..
www.citytel.net/~jleaman
mgoedeke
Hmmm, seems like car audio meets the home.
If you’re looking for a solid subwoofer driver, give http://www.blueprintdrivers.com a try. It might still be a while till they’ll have stock again, but a 1201 should do you fine. While you’re at it, give ESP a look at http://www.sound.au.com for articles, schematics and even some kits for active crossovers and amplifiers (even if it's just for inspiration). You might also consider changing your main speakers at some stage. Even though I cannot vouch for them out of experience, the following seem well designed with a strong emphasis on value.(http://www.speakerbuilder.net).
For a funky design, use speakerbuilder’s components and crossover (Parts Express), but put the woofers in an overstuffed sealed box. Then augment that with a BPD 1201 in side-firing configuration (in a 40-80l sealed box) and bi-amp at, say 250 Hz. Something like a poor man’s active NHT 3.3
JasonL
What about ported enclosure i would like to have a ported enclosure because it goes lower and doesnt require alot of power to power it at all eg my 15" sub sounded horrible and there techs at usd suck ***.. there usless and jerks..
i would like to make small but power full that is why i said 10" - 12" any one know if a good idea of a dual 8" bandpass box..
i had a band pass 10" and it killed my 15" sealed but now that it is ported it is good..
JasonL
jleaman@citytel.net
jason
kelticwizard
Jason:
A 10" ported will outplay a 15" sealed. Can I have an idea as to just how big you are willing to go, volume-wise, on your sub?
JasonL
I said that i had a 10" sub that out performed my 15 when it was sealed..
Silly.. : O)
kelticwizard
Yes, I was simply pointing out that your experience of a 10" ported outplaying a 15" sealed was a well-established phenomenon.
About how big a box do you plan to put your ported 10" into?
JasonL
I dunno it all depends i would l9ike to keep it small but what ever will work..
j'
kelticwizard
Depends on how you define "small". About the smallest I can come up with that will make a really good subwoofer is the Peerless XLS 10" 5 ohm, number 830452. This will have a 3 dB down point of 32 Hz in a 1 cubic foot box, (with a 3" diameter port), or 1.25 cubic foot box, (with a 4" diameter port).
A 3" diameter port will need to be 19" long. A 4" diameter port will need to be 34" long, and will require some PVC elbows from the building supply store to fit the port into the box. That is why you need to make the box 1.25 cubic ft if you use a 4" diameter port-it takes up more space in the box than the 3" diameter port.
The Peerless XLS 10" is about 86 dB senstive at 1 Watt, or 88.4 dB senstivive @2.83 volts.
The following graph shows the response for either of these boxes @ 1 Watt. The green line is the point at which the speaker is playing 3 dB below midpoint.
I can recommend other drivers if you want to make the box larger, say 2 cubic feet or larger. Those will go deeper than this 1 cubic foot enclosure will go.
JasonL
ok that sounds good so i have did some calulations how about 12" x 16" x 21 " and the subwoofer on the face of the 12 x 16
Height 16"
Width 12"
Depth 21"
And the port on the back of the sub so that it is facing back..
Also here is apic of my 15" usd sub when i just got it off a friend.
JasonL
Here is a perfect example.. of what i am wanting to build..
JasonL
Has any one seen onf of these subs..
Here is the link to there web page..
www.aerialacoustics.com
kelticwizard
Nice setup all round. Is that an Aerial Acoustics main speaker next to the subwoofer?
Assuming 1" thick building material, those dimensions yield a box of 1.9 cubic feet, so the Peerless XLS is out. Two 10" subs that come to mind are the Dayton Titanic Mk II and the Blueprint 1001. More about those later.
What kind of amp are you using for this, and do you have the power output into A) 4 ohms, and B) 8 ohms? Some subwoofer amps give considerably more power into 4 ohms than 8 ohms.
kelticwizard
Oops-too hasty. Actually, those outside dimensions will yield a box that is 1.5 cubic feet internal. forgot to subtact twice the thickness from the outside measurements.
The Blueprint 1001 and the Dayton Titanic MkII give almost identical performance in a 1.5 cubic foot box. The Blueprint driver is somewhat cheaper than the Titanic.
A 3" diameter port of 16" length tunes the box to 26 Hz. With these excursions-very long, 16mm-a flared port is a good idea. Available Madisound or Parts Express. Both charge $12.00
www.partsexpress.com
www.madisound.com
The Aerial Acoustic sub has an excursion of almost 2 inches. I assume that is back-to-front. These subs have an excursion of 33 mm back-to-front. That means a 3 dB theoretical difference in top volume. Don't worry, you'll never hear it. In a ported enclosure, you will not reach the limits of these subs' excursions. A ported box means your speaker only has to move 25% as much as a sub in a sealed box has to.
Blueprint 1001 is in blue, Dayton Titanic Mk II is in red. Green line is the line where output is 3 dB down from the midpoint:
kelticwizard
Jason: Quote your page: "USD pro c 15" 700watts single voice C....powering my 15" is a yamaha fixed buy me. has peaked at 620 rms with my meter at 42.hz into the sub.. just a simple one to get it running soon to have my 800wt amp mosfet ."
Actual power has everything to do with impedance. Is there anyway you can tell me the AC current at any drive voltage at 42 Hz? If 42 Hz is an impedance peak, and your meter measures simple AC voltage, then you are not approaching 620 watts.
JasonL
im useing a n-channel built buy me but desighned from e-holton to power my sub .
slicemaster101
well here are some relly goood 10inch subs.....
1.Blaupunkt OVERDRIVE ODwa1000
2. kicker C10vr
3. paniconic CJ-HD252
all are good 10 in woofers
i sugest #1 if you got to money
kelticwizard
quote:
A) Power into 4 ohms?
B) Power into 8 ohms?
C) Link to website with info on the amp?
The specs sometimes contain the info on power into 4 & 8 ohms.
ttvonau
I'm running a boss audio 12" daul voice coil sub in a 2.5 cubic foot cabinet with a 4"aero port.This sub has a 3" travel and moves massive amounts of air.Boss audio has a 10" version thats just as impressive.Check it out !
kelticwizard
Jason:
Okay, I'll answer my own question. I went to A. Holton's site-traced it through the "Search" of this forum-and found the construction booklet for the AV800 amp here. Here is the address for A Holton's site:
http://www.aussieamplifiers.com/index.html
It does matter if you are running a 4 ohm or 8 ohm speaker, though you can run either. Here are the specs, quoted from the construction booklet:
Specifications for the AV800 MOSFET Amplifier
All measurements were taken at an AC Mains input of 240 volts.
And with a 2kva Toroidal Transformer powering the Amplifier module.
Filtering with only 10,000uf per voltage rail
One channel only was been driven.
Frequency response 10hz to 100khz
THD measured at 100 watts into 8 Ohms 0.01% @1khz
Power Output into 8 Ohms = 450 Watts RMS
Power Output into 4 Ohms = 820 Watts RMS
Damping Factor = 400
JasonL
Im running a N-CHANNEL not the av800 im using a 350va with 40,000mf per rail at 75V and my case will be done soon.. every ones eyse will be PRYING AT IT i garentee it..
JasonL
kicker subs rule but i didnt know if i should go for another car audio sub, i had the kicker c10 ina band pass box and that is what killed the 15" usd sub that i had and it took hardly any power to move it too.. so i might again .. . but i want a ported box that punches il be using it for theater use and clean listening also.. im looking for a effician sub but if i need to illl put power into it no porblem.. my yamaha amp that i rebuilt runs my 15" with ease no problems but i want all fet and i would likea class a amp for my top end i have been foolin with some ideas for my new satelite speakers or towers.. havent decided..
J'
kelticwizard
Okay, I stand corrected. It is the N-Channel amp that you have already built and will be powering the sub, and the AV800 you are in the process of building now.
Anyhow, the following is from Anthony Holton's site. This is for the N-Channel:
http://www.aussieamplifiers.com/n-channe.htm
"The Amplifier featured below is a quasi complementary HEXFET N-Channel Power Amplifier. It develops 260 Watts RMS into 8 Ohms and over 400 Watt RMS into 4 Ohms."
Therefore, it is clear that it does make a difference if your speaker is 4 ohm or 8 ohm. The 4 ohm speaker will have a top volume more than 2 dB higher than the 8 ohm. You should primarily think in terms of 4 ohm, unless an 8 ohm speaker has considerably better performance.
Page generated in 0.055027961730957 seconds with 17 queries,
spending 0.00682807 doing MySQL queries and 0.04819989 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
