diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
Tube Newbie needs help - Click HERE for Original Thread
5string
I've got a box full of parts and stuff and I want to make a stereo amp or pair of monoblocks but dont know where to start. Here's what I've got, 1 Challenger Ch30 amp (2 6L6, 2 6CS7, 1 5U4G, 1 6SL7)(is mono with 2 MIC and 1 phono input) 2 6GW8's, 8 12Au7's, 2 big power transformers, 1 5Y3, 1 5U4, 1 6V6, 2 6C4, 1 6Au6A, 2 4wire output transformers, 2 5wire output transformer of different sizes and 1 small 7wire output transformer, add boxes of caps and resistors and general stuff. My thoughts are to salvage as much as possible from the CH30 (has a huge output transformer) and find a schematic for monoblocks of the 6L6's or maybe something small with the 6GW8's. Any first steps to get started? Any ideas to harness this mess into something usable (speakers aren't a problem, got 86dB's and 98dB's and some horns I need to test laying around). All help and ideas will be appreciated.
Thanks,
Alonzo
NickC
Given the tubes you have
I suggest you look for se 6l6 with a common power supply as you have one 5u4. This can be made to only power the output segment only. Then The 5y3 can be used to power the driver. You have suitable drivers that the 12au7. I suggest you can use them in a cascoding configuration to get the gain required. But i doubt the outut trans can be used since it looks like a push pull trans without airgapped. Hope this helps though
5string
Thanks Nick,
While I search for schematics and wait on transformers to come in (gonna try for 6L6 monoblocks) I'm going to get my feet wet with a stereo 6GW8 using the PP transformers I have (and the small output trannys). Do you know of any 6L6 SE schematics?
Page generated in 0.020004987716675 seconds with 16 queries,
spending 0.00826645 doing MySQL queries and 0.01173854 doing PHP things.
Copyright ©1999-2009 diyAudio.com
