diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
Need Advice on new Amp - Click HERE for Original Thread
Bryan
Hey Guys,
My solid state amp (Krell KSA 100S) blew up, and is beyond repair. I need to replace it with something a little more appropriate (ie. tube). I know this is the DIY forum, and I have a few DIY amps in the works, but I like to have one commercial amp for wihich to compare my DIY stuff. So, that being said, I need a new refference amp, and I would like your suggestions.
System:
NAD S500 (Transport) Soon to be replaced...
AudioNote DAC KIT 1.2 (Modded)
Audio Research SP9MKIII, or DIY 12B4A preamp
(Fill in the blank)
ProAc D15.
I want to keep it in the 2-2.5K range. Thinking about AR VT100MKII.
Ideas?
Thanks,
Bryan
Eli Duttman
Bryan,
IMO, you should think long and hard about acquiring and refurbing a Harmon/Kardon Citation II.
I own a Jim McShane refurbed Cit 2. The amp is GREAT. At 60 WPC continuous and 120+ instantaneous, all but the most power hungry speakers are suitable for use with the H/K. ARC makes good amps, but the "iron" in the H/K is BETTER.
Page generated in 0.081046104431152 seconds with 16 queries,
spending 0.03676844 doing MySQL queries and 0.04427767 doing PHP things.
