I want to connect a Perp Tech P1-A reclocker straight to a TDA1543, if indeed such a thing can be done.
The output is I2S via a 5 pole mini DIN socket. Anyone know which pole is BCK, and WS and DATA? What should I do with the two remaining poles?
Couldn't find anything in the archives, so thanks in advance if you can help.
Sandor
Test the pins with a frequeny meter. The pin with the highest frequency is BCK. Usually WS frequency is a quarter or half of BCK frequency. DATA has no output when there is no spinning CD.
