diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
Will this work? "Mixed" 300B PPP IT - Click HERE for Original Thread
ppereira
Will this work? the driver tubes are either ECC99 or 6C45's.... Phase splitter is a Sowter 8920 Transformer. Each phase of the driver stage is IT coupled to two paralleled 300B output tubes via a Lundahl 1660 transformer in SE to SE configuration.
Thanks,
Fuling
I can´t see any reason why it wouldn´t work, but is there a point in this concept?
cuallito
Why to be different of course!
ppereira
No, no point... except for re-using parts that I already have... and to be different off course... :)
Eli Duttman
A cautionary note: with simple cathode bias, the 4 "finals" have to be CLOSELY matched. Obtaining CLOSELY matched quads of 300Bs could be quite difficult.
Implementing Dennis Boyle's combination bias would provide a means by which imperfectly matched tubes are compenstated for.
Use unbypassed 220 Ohm cathode resistors "under" each "final". A bias supply combined with 4X individual bias adj. pots. allows the setting of the "finals" at identical idle currents.
Page generated in 0.018424034118652 seconds with 16 queries,
spending 0.00744843 doing MySQL queries and 0.01097560 doing PHP things.
Copyright ©1999-2009 diyAudio.com
