diyAudio.com diyAudio Forums Archive > Top > Source > Analogue
a little help with phono preamps/cartridges - Click HERE for Original Thread
bonsai171
hi, can somebody tell me what type of phono cartridge is in a Philips Electronic 222 turntable? thanks
Dave
bonsai171
there are electronic controls on the record player too. There are buttons for start, stop, 33, and 45. If you press the 33 button (to select 33) then push the start button, the arm comes up, moves over, and goes to about the middle of the record, instead of at the beginning of the record. Is there an easy way to fix this?? tia!
Dave
peranders
Probably, you can use any pickup with not too "loose" stylus. If you could take a picture I would be easier to tell. I was around in the 70's and Philips so I may recognize it.
About your tone arm. You obvoiusly have to do a surgery. Try to remove the platter and open up the TT.
bonsai171
Here's the turntable!
Page generated in 0.038290977478027 seconds with 16 queries,
spending 0.01305294 doing MySQL queries and 0.02523804 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
