diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
I2S cable DIY? - Click HERE for Original Thread
tomchaoda
Has anyone make his/her own DIY I2S cable before?
If not, any where I can find the spec and parts to do it myself?
Thanks,
Thomas
Elso Kwak
Thanks,
Thomas
Hi Thomas I just bundled together three 50 Ohm pieces of coax between CDP and DAC. The type of cable Mark Levinson was using when he introduced the ML1-preamp with Lemo connectors.
:idea:
Coulomb
quote:
:idea:
Hello Elso, How long were those cables?
There is so much discussion about how long a run I2s can support. Under optimal conditions I understand 20 cm in an internal chassis is max.
Anthony
Elso Kwak
Anthony
Hi Anthony,
I used this scheme, which has more drive than just connecting the chips directly. Between CDP and DAC is about 70 cm.
jaycee
I thought about this recently, and thought of using differential line drivers to transmit the I2S signals, over a standard CAT5 network cable. While I doubt you'd get more than a few metres distance it'd be plenty for an interconnect... and no making up your own cables :)
Coulomb
Hi Anthony,
I don't suppose you made a little PCB for this did you?
Anthony
Page generated in 0.11284589767456 seconds with 17 queries,
spending 0.01027036 doing MySQL queries and 0.10257554 doing PHP things.
Copyright ©1999-2009 diyAudio.com
