diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
Do someone knows how to change the crazy way i wan't? - Click HERE for Original Thread
destroyer X
I never find..... an amplifier that can work class A till the beginning of clipping..... and, when clipping starts the input is reduced around 10 percent and an special new output stage is switched on.
The "special output" with high voltage..... something alike plus and minus 80 volts...and.... the first class A amplifier is switched to AB class automatically when volume is increased or audio input is increased .
It is confused?.... i know that!
I put a schematic, a class A schematic that simulates very well and i will assemble.... but 30 watts in 4 ohms is less than i want.
So, when i reach distortion i want this amplifier to switch to AB... this way the power will increase.....in this moment a reduction in input signal to prevent override.... and same time another output is conected to the 30 watts class A amp (Already switched to AB) and this output have higher voltage on their output transistors....
that's not crazy...... but i already know i am crazy!..... sorry....but a suppose all off us in this forum has some mind disturbance.... some brain diode shorted or something alike.... so..... i think i wellcome to this brotherhood.
Carlos is the Destroyer X, and will put a lot off brazilian schematics to you all improve.
chris ma
Hi D-x Carlos,
You should look for the updated version with two ccs. The version that you posted RV2 is rather difficult to get in good quality it needs to be around 2watt or above. I think it was said that this circuit can not will not work in class ab, I may be wrong here...
Chris
phase_accurate
If I understand correctly then you'd like to build something like a class G amp that runs class A at low levels. You will need a complementary design if you want to do this.
Meyersound uses such an amp with their X10 active studio monitor.
Charles
sreten
D.Selfs class G amplifier can be configured to
class A with rail switching at class A "clipping".
:) sreten.
destroyer X
Thak you by the cooperation and your good compreension related my truncated english.
If you can have the schematics, send me or put it here.
Having not..... no problem... and be happy!
Carlos
destroyer X
Thank you Sreten..... if you know where i can find more info. rellated to that kind of amplifiers, please, let me know.
Carlos
phase_accurate
quote:
D.Selfs class G amplifier can be configured to class A with rail switching at class A "clipping".
That's a worked-out example for which even PCBs are available! I don't have a scanner unfortunately but maybe soemone else does, who has the respective issue of electronics World.
Charles
destroyer X
I will find in the web some infos related to this machine you talking about.
Scanner sometimes is good.... but we can go without it too.
You welcome.
Carlos is same as Charles.
Brian Donaldson
deslf
Brian Donaldson
Or the place that sells the boards
signal transfer uk
Maybe the inner transistors could be biased up to class A. Poke around, This guy has lots of good reading material.
destroyer X
Thanks your message..... i sent some message to your E Mail.
Carlos
B.I.G
Does anyone have the Douglas Self class-G am schematic ???? couldn`t fiint it on the net :bawling: :dead:
Nelson Pass
quote:
US Patent 4,115,739 (Sano et al) is the best example yet.
destroyer X
I run to bring the red carpet.(not joke to Royalty...not kidding)
And always welcome you, feeling honored with you presence
.An those words are not ironic words, nor false, nor untrue or other meaning different the clear english translation, without hidden intentions.
I do not prove my respect and good impressions about your work, because i have not knowledge to talk with you... i have to stay listening for some years to start conversation. I do not know deeply fets, reading and understanding this strange and incredible component... sometime i will assemble some amplifier using it.
You are not a common mortal... one magnificent example of a deep knowledge man
The way you write, the logical sequences, the clear ideas, the Pass A40 impressed me very much.
This way, always you came i became ashamed my ignorance, and force myself to put pride in trash and give to Cesar, the things that belongs Cesar.
Carlos
Thanks and welcome to honored my person with you attention.
Carlos
Page generated in 0.036726951599121 seconds with 17 queries,
spending 0.00839067 doing MySQL queries and 0.02833629 doing PHP things.
Copyright ©1999-2009 diyAudio.com
