diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Permeability - Click HERE for Original Thread
Anvil
Hi. Does any of you have a list of permeabilties of different metals. I would like to know permeability of copper, u-metal, stainless steel, aluminium and steel. What other things matter to magnetic shielding than permeability?
weinstro
Relative Permeabilities
Iron 150
Permalloy 8,000
Nickel 110
Steel 50
Mu metal 20,000
Copper 1
Aluminum 1
Stainless 1 (depends on composition)
Personally, I would be looking at how the material is to work with, i.e., cutting, drilling, welding, bending, etc.
Rob
Anvil
Hi. What happens to stainless steel`s permeability when it is heattreated or welded? Thank you for your list.
Steve Eddy
quote:
Thickness and saturability come to mind. Generally the higher permeability materials saturate at much lower levels and once the material saturates, it's no longer effective as a shield.
se
johnferrier
I like to refer to figure 16 here: http://www.analog.com/UploadedFiles...76254AN-347.pdf
BTW I like steel's shielding ability (easier to get and work with than mu-metal).
JF
jneutron
John...nice graph, thanks..
Anvil...skin depth of the material plays a role also.
depth (cm) = 5033 * sqr(p/uf)
p is resistivity in ohms per centimeter cubed
u is permeability for low flux densities
f is frequency
When SS is welded, it can allow precipitation of carbon, rendering it magnetic. Also, it can become slightly magnetic when machined.
Cheers, John
sreten
Fresh air, i.e. distance is much cheaper then anything else.
:) sreten.
Page generated in 0.026619911193848 seconds with 17 queries,
spending 0.00857615 doing MySQL queries and 0.01804376 doing PHP things.
Copyright ©1999-2009 diyAudio.com
