diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
two bulbs at the same time - Click HERE for Original Thread
Iron Man
I've got two 250 watt bulbs and balasts lying around, would it be possible to run both of them at the same time?
I'd need to put them quite close together in order for them to remain in the centre of the fresnel's line of focus. How close could they be before over heating? and how affective would this be compaired to using a single 500w bulb?
I could place a very thick piece of low e in between them
Iron Man
... i think i remember someone saying that their ohp had the option of running both the spare and the origional bulbs at the same time for xtra brightness. Does anyone else have this and how far apart are the two bulbs?
doughboy
Are they the big bulbs or the double ended tubes?
You could put one right behind the other, but the bigger the bulb ,the bigger the problems. You need a point source for use with a fresnel (for DIY), the smaller and brighter the better. If 250 is not enough, you probably be better off with one 400.
Heres an older thread with some bulb on bulb action.
Iron Man
They are 4.5cm high and 1.5cm width ways. Single ended
I cant realy give any other info about them
Iron Man
Great, thats solved all my problems. I cant believe u can just stick them right next to each other like like that.
Though I did search, Id just like to appologise to whoever for not finding that post.
bobharry
If you want a slightly harder way to do it, you could use a 50:50 beamspliter at a 45 degree angle infront of one bulb and the other bulb to the side so that is reflected off the beamsplitter, this would mean you still use both bulbs but they are both the right distance from the fresnel and in the center.
Iron Man
Thats not a bad idea actually, Both ways will be a little hard. I think ill look in to the costs and see which is cheapest and which one takes up most space etc
Page generated in 0.088013887405396 seconds with 17 queries,
spending 0.00988007 doing MySQL queries and 0.07813382 doing PHP things.
Copyright ©1999-2009 diyAudio.com
