diyAudio.com diyAudio Forums Archive > Top > Source > Analogue
Any website reference fo diy turntable? - Click HERE for Original Thread
bmpa
I don't want diy with kit, I want diy arm,cartridge,transport,motor and power
HBarske
http://www.formgestalter.com/krishu/gallery/gallery.htm
jelou
What motor do I need and arm?
I also want to diy a turntable
bmpa
Can I use some industry motor to build my turntable?
What motor speed do I need?
HBarske
Of course you can. Everything else should become i little bit difficult.
The platter needs to totate at 33 1/3 rpm. use a motor pulley of the right diameter to achieve that speed, or, use a motor with adjustable speed control.
krishu
i built my tt myself (Holger posted a link to my gallery of other diy tts above), you can read about the details on www.krishu.de > hifi > turntable
i built an unipivot tonearm wich performs at least significantly better than a Rega arm. I tried several approaches of motors and controls, ended up with a (internally) PLL regulated cassette tape deck motor, supplied with a standard LM317 regulatet P/S.
My Schroederclone (which is the best design for diy i suppose) is still in progress, too many projects at once.
my future plans regarding my turntable concern only motors. I want to try expensive Maxon motors and Papst motors later on. I got some response from the motor manufacturers and they told me which turntable manufacturers buy their stuff there ;) The main problem with most motors is that these have ball bearings which are no-go for turntables. and the voltage-regulated maxon motors are difficult get speed-stable.
Cheers
Christian.
jelou
How can I diy the arm and the cartiage?
What material do I need?
krishu
Be creative! Look at commercially available arms, add your own ideas and start building.
Apart from that i think you better buy a cartridge, DIY is too difficult here.
Cheers
Christian.
Page generated in 0.030098915100098 seconds with 17 queries,
spending 0.00927806 doing MySQL queries and 0.02082086 doing PHP things.
Copyright ©1999-2009 diyAudio.com
