diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
Just alittle more help please - Click HERE for Original Thread
blackie
nview ViewFrame Spectra
:whazzat:
how do i get it to stop rolling and it has no color
i've tried the remote
i'm useing my stand along dvd player thru composite
thanks again guys
blackie:confused:
Dnt32
640 x 480
ace3000_1
Heya blackie, you can ask what you want in here as manny times as you like.
Try to see what the output of the dvd player is, by this i mean is it pal, ntsc, secam ect...
The set your panel to the apropiate format, it sounds to me your trying to run pal with the panel set to ntsc.
Trev
blackie
My DVD player is a APEX IT PLAYS dvd; mp3; kodak picture cd,
and you can set it to pal or ntsc
i know i might have to get a cheese box
but i was hopeing to just run stright thru lol
don't have computer cable yet
but i got panel; power cord and case for a dollar and 20.00 shipping not bad right
thanks again
blackie:D
ace3000_1
heya buddy, you should be able to run it dirrect by just changing the format on either the panel or the dvd player, just make sure they match or are the same, it should work no probs. Might save you some cash.
Btw, you got a bargain on that panel lol
Trev
blackie
on my panel remote it has
reset
focus
palette
lcd -on
lcd-off
<horiz>
<vert>
<color>
<tint>
ohp-on
ohp-off
thats it so it will have to on the dvd player lol
thanks
blackie
blackie
power on the inside is loose i have to wiggle and push and pull
to get it come on and stay cold joint i think
well take it apart and resolidter it lol
blackie:dead: :att'n:
wout
make sure your monitor is 640x480 and 60Hz when using the computer. it only has 4000 colors btw.
.. you say it is a Nview Viewframe Spectra and your using composite... but that panel only has VGA input?!?! (i had the same panel) are you sure you have that panel?
blackie
yep it's got composite i got it apart now doing some work to it
it's got
video from computer
analog
digital
composite
optional monitor
accessories
some other thing
power
blackie:D
wout
hmm maybe some later version of the panel then i had.
btw maybe you should check your dvd player settings.
sometimes you can choose between different video output settings, like PAL or NTSC. switch between them and look if one may work correctly (i wouldnt know which one :))
blackie
this one 1991
i hope i got it right this time lol
blackie
thanks:smash:
hostar
Hi guys,
I have been lurking around these forums and am intersted in building a OHP system. MY question is what is the best LCD to put on the OHP and also, is there away I can get component video on to the LCD and use a dvd player to play the movie? Instead of a computer?
I tried searching for component LCDs but didn't find anything. Also any sites with the basics of retrofitting MH in OHP?
Thanks (be gentle newbie at hand):D
Page generated in 0.028604984283447 seconds with 16 queries,
spending 0.00812244 doing MySQL queries and 0.02048254 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
