| Lukman |
The model wasn't LQ 1500 but QA 1500. still no reponse on the panel. |
| Poseablejesus |
I have a 1500, what specifically is your problem?
no input from rca, or vga?
If your talkign about vga from your computer... Make sure that your resolution is set at 640x480.
On mine the image will also display at 800x600, but part of the image is missing from the bottom.
If your talking about your rca unput not working... Use the search feature... I have seen a few posts concerning this same issue.
Some were fried, some just dirty or repairable.
Good luck |
| Lukman |
I think the problem is with VGA.
I want to used the panel with my computer. I have changed the resolution to 648 x 480 with 256 color but there's no response on the panel.
Another thing is, which cable should I connect to the computer? There's tho pin on the panel; one with 15 pin (monitor out) and the other with 30 pin (computer in)? I connect my computer with the 15's pin cable (I wasn't sure if this is the right cable or not as the panel comes only with this cable).
Many thanks for your the reply. Hoping could use this panel to do my presentation in class before next month. |
| Poseablejesus |
Wrong port.
You need a cable to go from your video card to the 30 pin (computer in) connector.
The 15 pin (monitor out) goes to your monitor so both will display at the same time.
you need to find one of the 15 to 30 pin cables. |
| Poseablejesus |
Also...
the 1500 will run fine at 16 bit color. |
