diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
Electronics Workbench 4 opamp sim bug. - Click HERE for Original Thread
Circlotron
A friend gave me his old EB4 a few months ago because he never used it, and I finally got around to playing with it the past weekend. (Full-blown SPICE etc is too hard for me!) Anyway, I had a nice little opamp circuit chugging along driving a source follower, and the zero voltage point of the opamp supply rails were referenced to the source follower output. This method is interesting because the demands on the opamp are very low as regards slew rate etc. Anyway, I found out that this simulator measures the slew rate of the opamp with respect to earth, not with respect to it's supply rails which in this case are going up and down almost the same amount as the opamp's output.
Do other simulators have this problem?
Page generated in 0.015788078308105 seconds with 16 queries,
spending 0.00779057 doing MySQL queries and 0.00799751 doing PHP things.
Copyright ©1999-2009 diyAudio.com
