diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
Home Theater PC - Projector DEAL! - Click HERE for Original Thread
sbrewer
Would anyone be interested in purchasing a used industrial computer with the following attributes. I originally got mine with the intent of making it into a car PC, but I found it was better suited to a projector. I took apart the LCD yesterday and the cables and controller require no modification:
Specs:
LCD: 10.4 inch 4:3 aspect 1024x768 TFT, I looked and I think the contrast ratio is 250:1 and the response time is 50ms....not bad!
Touchscreen .....Nice, but I can't get it to work in XP, only 98.
Computer: 400Mhz Celeron, 6gig 2.5 inch Lappy HD, 64MB PC66 SODIMM (I put a 128MB in and it has 32MB on board). Onboard Coax TV-Tuner, 2 x PCMCIA slots, 10/100 network card (PCMCIA), 1 USB 1.1 port, PS/2 port, VGA out, win98
It all comes in a nice metal case (it was a kiosk computer in its former days)
It has somewhat odd power requirements though....24V, 3Amp. I am currently using a Radio Shack PS rated at 30V,1Amp, as are several other people and it works fine. I has connectors that will need to be stripped before you can power it on, but it is not hard and it comes with all the pinouts.
I can get my hands on a lot of em, I have a lead time of about a week.
If you want one, go ahead post, email me (sbrewer@alum.rpi.edu), or PM me.
It will play DIVX and MPEG-2 great.
$220 shipped.
Questions?
email: sbrewer@alum.rpi.edu
PICS:
www.brewersonline.net/PC
Aidan Isaac Lev
Could you check if it is powerleap conpatable? that would be good info to have in theis thread:)
sbrewer
It is a laptop motherboard that seems to have a Micro-PGAI socket, which can be upgraded to about 500mhz...I have seen celeron 466's on ebay, but nothing higher.
Page generated in 0.032941102981567 seconds with 17 queries,
spending 0.01665640 doing MySQL queries and 0.01628470 doing PHP things.
Copyright ©1999-2009 diyAudio.com
