| peranders |
Hi!
I'm a DIY enthusiast from Sweden. In the daytime I work as a design engineer and in my spare time (recently started) I design extreme performance amps made of ordinary components.
As you can see (if you check my homepage, I'm not the minimalistic guy. I love the design process but I love also to listen to music. I have Martin Logan SL3 electrostatic speakers, my own power amp MOSFET-QRO called (published in a hifi magazine long time ago), my own CS4328 based DAC, DENON preamp, CD and tuner, Hitachi CT-A9X cassette deck (rather expensive) and an old JVC turntable from the 70's. |
| wuffwaff |
Welcome to diyAudio.com!
I had a short look at you website, nice stuff!
william |
| sonnya |
Hi Again Per.
I have a question for you.. Did you work for a small Engineering firm in the 70 .. mid 80's where you build amps with build in electronic crossovers?
You see my father have some old equipment wich have some rather special modelnumber like you are using... He has only the preamp left...
But the casing which where used for the poweramp look a lot like the old ones shown on your page... A coencidence?
Sonny |
| peranders |
I was a teenager in the 70's. Maybe I recognize the amp if you tell me more.
QRO = I increase the output power
QSX = Which frequency are you listening/transmitting at
QRV = Gear ready to be in use
These are morse signals from second world war... and there are lots of them...e.i mark your position with smoke signals. |
| sonnya |
The preamp is named "IFM PREAHQ" and it is from sweden.
So i thought it could be you. But it is not named the same way..
Sonny |
| peranders |
| Sorry, never heard of it! |
