diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
my second GC attempt - finished - Click HERE for Original Thread
Rafal
Hi everybody,
I thought that I would share with you my second GC attempt.
I think it looks nicer and IT WORKS :D
I would appreciate your comments.
Here are the pictures:
Rafal
Here is a picture of the closed case...
This is based on the Peter Daniels' design with Brian's boards.
I have one problem though. I keep blowing fuses (between line and the primaries of the transformer). I have used 250V 4A and no luck.
Any suggestions...?
digi01
COOL!
It seems that the TRUNK Router inside the network.very ahead fashion.
Rafal
Thanks for your comment. I really appreciate it.
What do you mean by Trunk Router?:confused:
Rafal
BrianGT
Rafal,
Looks good!
What are you going to do with the second set of pcbs that I sent you?
As for the fuses, are you using slow-blo fuses? I am using a 3A slowblo for mine, and have never blown it. Others have said that a 2A slowblo also works fine. Are you blowing fuses at turn-on?
I added your pictures to my new gallery of finished amps with my boards:
http://brian.darg.net/gallery/nigc
Brian
Da5id4Vz
The big red caps, are they on the inputs?
Love the dimond plate.
BrianGT
quote:
I moved the gallery over to my new website.. I keep on forgetting. Please visit:
http://www.briangt.com/gallery/nigc
To others with finished project using my kits and pcbs, feel free to e-mail me pictures, or post them in a thread, and I will add them to my gallery.
Brian
digi01
Rafal,The appearance of your CLONE is terse , durable. Let me recall that is full of network equipment of industrial aesthetics such as ROUTERS.
cheers!
Rafal
Rafal,
Brian
Hi Brian,
I was toying with the idea of buildiing a second amp fo an active amplification of jordan 2-way, but for now, I will build a set of horns instead. The boards will have to wait a little longer. Maybe I will make an amp for a buddy.
Hi Da5idVz,
The big red caps are for ensuring low dc offset. they are placed between Reiken 680 ohm and signal ground
Thank you all for your comments
Page generated in 0.030741930007935 seconds with 17 queries,
spending 0.00888157 doing MySQL queries and 0.02186036 doing PHP things.
