diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
bridging an LM4881 headphohne amplifier? Can it be done? - Click HERE for Original Thread
soundNERD
Hi, I have a some LM4881 chips and have built a headphone amplifier for my portable CD player. The sound is excellent, so I would like to bridge them. The problem, though, is that they only have one input. Is there any way to bridge them short of using something like a DRV134 to invert one amp's input?
thanks!
mike
Alexander Rice
just stick an inverting buffer before one of the amplifiers
soundNERD
like the DRV134 right? that takes one signal, invertes it, balences the inverted and non-inverted inputs then has two outputs of the same signal, inverted and non-inverted.
The only problem with that is I only have one and would need two for stereo. I don't think with headphones you would notice the difference when one amp is inverted and not the other, so I could just stick an inverting opamp before the input of one of the amps, right?
Alexander Rice
that is what i said :) - inverting buffer = inverting op amp with unity gain, any old thing'll do as long as it i unity gain stable since even TL072 will have a bandwidth well into RF, i reccomend the NE5532 for this type of thing for it's low noise and good value
soundNERD
OK!
Thanks!
-mike
paulb
Do you plan to modify your headphone cable to separate the common connection to each channel? Bridging won't work with a 3-wire cable; you need all 4 wires.
soundNERD
yes, my cable is from a standard pair of headphones, so the connector splits into two seperate cables, one with L and gnd, and the other with R and gnd.
thanks for pointing that out though.
-mike
Page generated in 0.021647930145264 seconds with 16 queries,
spending 0.00868607 doing MySQL queries and 0.01296186 doing PHP things.
