diyAudio.com diyAudio Forums Archive > Top > Source > Analogue
Electret Headphone transformers for MC use? - Click HERE for Original Thread
KBK
I have a old set of Toshiba headphones that are transfomer driven, in separate box.
they are 20 to 20k response. The panel or wire in one (left or right headphone) is dead. I am wondering if the transformers might be good for MC cartridge loading. Any guesses? I can do the test work myself.. but thought I'd ask you guys and maybe create a discussion on this odd subject.
BrianL
doubtful. the headphone transformers have high turns ratio
to drive high impedance (actually small capacitance) 'phones.
MC needs very low Z to not-so-low Z and much shielding.
The two sets of requirements are almost diametrically opposed
KBK
I failed to mention: The headphones are speaker level input only. they need to be driven by a power amp. Like the stax SR-44's I have. Same thing. So they are definitely low z on the one end.. Sorta. Maybe. Perhaps you took this into account in your reply. Thanks for your effort!
sreten
Even if the impedances match your into an area I seldom see discussed.
The transformer will be too large, it would need too much magnetisation current ?
As far as I'm aware the smaller the transformer the better for MC's,
due to I presume due to low magnetisation / hysteresis loss ?
:) sreten.
BrianL
also, the turns ratio needed for the ES headphones will be
far greater than you need for the MC cartridge
Page generated in 0.020754098892212 seconds with 16 queries,
spending 0.00930643 doing MySQL queries and 0.01144767 doing PHP things.
Please support our sponsor.
