diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
probably a stupid questions about opamps - Click HERE for Original Thread
soundNERD
can an opamp be used as a voltage amp? I want to boost 12V to about 40V.
Basically, a car amp power supply.
thx,
mike
digi01
You may need DC-DC chip of solid state.
dkemppai
An opamp is designed to output voltages within it's supply limits. Unless you used a transformer to step that voltage up, you won't get any higher voltages out of the amp.
As digi01 has stated, you may want to look into a DC-DC converter.
-Dan
Page generated in 0.014738082885742 seconds with 16 queries,
spending 0.00641727 doing MySQL queries and 0.00832081 doing PHP things.
Please support our sponsor.
