diyAudio.com diyAudio Forums Archive > Top > Source > Analogue
Modifying RIAA playback for 78 rpm/45rpm - Click HERE for Original Thread
ashok
I keep reading that it is possible to get better results with a variable RIAA playback curve for 78 rpm records. What do they really adjust ? I guess it must be the corner frequencies but by how much ?
Is this also applicable to 45 rpm plaback ?
Anyone on this forum who does these things ? Any sites that I can check out with such information ?
Thanks.
Ashok.
sreten
33 RPM and 45RPM RIAA eq is the same.
78's used lots of different curves.
A MM fitted with a 78 stylus will not be right through a MM input.
Sometimes I think for 78's a ceramic cartridge that does
not require any EQ at all would be the easiest option.
:) sreten.
Havoc
Read and enjoy: http://www.rfwilmut.clara.net/repro78/repro.html
ashok
Hi Havoc and Sreten,
Thanks for the info. I think that all I wanted.
It has everything that I was looking for.
Thanks again.
Ashok.
dvautier
I run the ceramic 78 RPM output right into my sound card. Then I equalize as needed. when I say "as needed" I mean it. The records are wildly different depending on make, model, year and condition.
I have some web pages on this subject. The discussion under technical page may help. hope so.
http://dvautier.home.comcast.net/records/records.htm
hagtech
We adjust the corners and turn frequencies, just as you thought. 78s were recorded with many (dozens) of equalization curves. There are three main inflection points, one at a low frequency (50Hz for modern RIAA), a mid-band (500Hz), and upper (2122Hz). More info here:
www.hagtech.com/equalization.html
and
www.hagtech.com/pdf/riaa.pdf
I don't believe 45s have this problem, they don't go back as far. But don't quote me on that.
jh
Page generated in 0.02503490447998 seconds with 17 queries,
spending 0.00808620 doing MySQL queries and 0.01694870 doing PHP things.
