| Cephas |
the aleph2 output mosfet IRF244
can be bypass with IRFP244 (Vdds 250v RDS 0.28Ohm ID 15A)
and IRFP240 also.
IRFP150 160 044 can or not? (Vdds lower )
i heard that lower Power mosfet have better sound. is it right??
thanks. |
| AudioFreak |
well lower voltage fets add less distortion.
the other major factor is the capacitance ... you really have to look @ the individual situation and then try to minimize the capacitance.
IRFP240 is fine ....
I wouldnt use the others as voltage is too low for comfort. |
| Gabster |
| Are you saying that the IRFP244 is not suitable? |
| AudioFreak |
| quote: | Originally posted by Gabster
No, I'm not saying that.... i was referring to the list of possible alternates cephas provided.
For Aleph 2, you could happily use irfp240 or irfp244. |
| WayneS |
| IRFP240 is the correct answer. |
| till |
sorry, one little question related to the first posting in the thread: whats against IRFP150? I just build yesterday the light bulb ZEN, and the IRFP150A was the only MOSFET i could get here fast and cheap (3 Euro). It´s 100V and i build a 85V DC 3,7 A powersupply with a 300W 220V bulb.
In wich points a IRFP240, 140,040,044 etc. (i´m not able to get here) are better? And whats about IRFP250 or IRFPC50 ? Thanks for answering this. |
| WayneS |
Till,
Sorry, don't have time to go into everything on this. If I remember correctly, the 150 is a monster with huge current capability and rather "gross" properties, such as the gate capacitance, charge under the gate, etc. This means it's slow and needs a bunch more drive. You use a single 150 in a ZEN, but 6 '240s in an Aleph, for example.
The 240 has high voltage and relatively large current capabilities, and the parasitics that would slow it down are smaller, which means you don't need a honking huge driver stage and it's faster on transients. It is also readily available to US DIY'ers at Digikey - I don't know about foreign shipments on parts like that.
Get yourself the datasheets from the International Rectifier website, and just compare the parameters one by one until you see a transistor that suits your needs. For an Aleph 2, the 240 is your baby. |
| till |
| Thank you for answer. Shure, i studyed all this data sheets. Main differences seem to be IRFP150 :100V, Id 42A and IRFP240 : 200V and 20A. Ok, both i think is enough, more than we need. Output capacitance of 240 and 140 is about 1300pF, the 1900pF of the 150 is not much more (?) and to IRFP240 parallel is much more than one IRFP150. One different value i don´t know to judge about: What s forward tranconductance (Gfs)? its 6,9 S (Siemens?) at the 240 and the double (14 S) for the 150. what does this? I´m interessted in this diskussion about 240 (or 044 or so) versus the easy to get and cheap 150 type because i plan to buy some more for further projekts, and i searched the forum, others used the 150 too, but i found no comment about its quality versus the other types. |
| Peter Daniel |
In Zen Variations-Part 1 Nelson Pass states:
"I have specified the IRFP240 MOSFET transistor in Fig.5, but a wide range of similar N channel devices work fine. The best performance is obtained with the IRF040 or IRFP044, but unfortunately they seem very difficult to get. An in-between alternative is the IRFP140."
"The lower voltage chips of the same type will give lower distortion, apparently due to their lesser sensitivity to voltage fluctuations on the Drain. They are generally the preferred parts".
Wouldn't IRFP140 be a better choice than IRFP240 then? |
| cp642 |
| apparently ...yes but...to echo Audiofreak's word of caution, the 140s might not be suitable for some application as you might be running it closer to its voltage rating. |
| AudioFreak |
| For the higher powered Alephs, I would strongly advise against using the 140 or 044 as the voltage rating is not sufficient to allow a satisfactory safety margin. Either 240's or 244's are fine for the job. |
| Cephas |
so how about 250 compare with 240?
thanks. |
| AudioFreak |
2 x 240's in parallel are better than 1 x 250
as has been said before, your best to stick to the schematic and use 240's or 244's either are fine |
| HarryHaller |
| How big of a heat sink would I need for that? |
| fcel |
| Harry: Another heatsink question for Aleph 2? Are you sure you're not a comedian? |
