diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
Best choice for in/out caps Aleph p 1.7 - Click HERE for Original Thread
bbakota2000
Please help me, last two weeks I spend looking for good quality capacitors for input and output (10uf) in P 1.7. I'm completely confused. Is it good to use high voltage ones? Please suggest a brand or anything that will provide me with most transparent sounding caps.
THANKS!
uli
Supremes
Uli
:nod: :nod: :nod:
Alain Dupont
bbakota2000,
You can find:
Metallized Polypropylene Film Capacitor made in France
like these at: www.solen.ca
For input caps...;)
Panelhead
To my ears, once the values go over 2 - 3 ufd the best coupling caps are Black Gate NX. The 10 ufd plastic caps have always sounded a lttle rubbery in my systems.
George
yoke
Hi bbakota...
I do remember that people post that they have best results with BG...
yoke
Black Gate NX...
till
WIMA MKP10
trigon
Yes - WIMA MKP10
Trigon
Asen
What about VISATON 10uF MKP 250V? I have 16 pcs of them but haven’t tried them yet. What I see as a drawback - they're rather big.
till
quote:
they're rather big.
What do you think is the size of Wima MKPs? (i would not wonder if they are from the same manufacturing line)
I use wima MKS, have no problems, and they are smaller than MKP but still not really small. But much less expensive.
wuffwaff
I´ve used WIMA MKS4 10 MuF in my X-BOSOZ and ONO projects.
william
bbakota2000
Would it be good to put Black Gates N series for input and Solen or WIMA for output. I think that input caps should be much better than the output ones in P 1.7. Any suggestions on this!
zygibajt
Siemens MKV :devilr:
till
In case you really belive electrolytics are (good) capacitors - do so.
I will not.
Peter Daniel
Let me pour some snakeoil. I belive that BG N type caps are much better than those Wimas. BG N caps are not your usual electrolytcs, but special blend that outperforms all the other electrolytics in coupling applications. I prefer them even to Jensens and Hovlands caps. ;)
PS: If you check percyaudio.com catalog, this is what he writes about those caps:
"Unrivaled performance in a unique graphite impregnated electrolytic design with ESR 1/5 to 1/20 that of
ordinary electrolytics, minimal phase delay, and extremely low noise floor, exceeding -160dB for some models.
No other electrolytic compares for low distortion, sonic purity, and extremely long life (up to 10X other electrolytics)."
He also had this piece of info posted on his site previously, but I guess it was way too much snakeoil so he removed it.:)
chris ma
Thanks to Peter here is the caps that I have tried....
http://www.diyaudio.com/forums/show...7956#post267956
Chris
Peter Daniel
Yeah, Siemens MKV is one of the few caps that are better than BG N for coupling.;)
zygibajt
In a couple of weeks I will show new Aleph P 1.0 here.
All coupling caps will be huge cans Siemens MKV
It will use Siemens Sikorel 125 PS caps and Elna ladder type attenuator.
Bartek
bbakota2000
Does anyone know where can I buy Siemens Sikorel caps?
zygibajt
Probably Epcos now,as Siemens company has been bought.
I bought mine NOS in a surplus store.
Page generated in 0.038747072219849 seconds with 17 queries,
spending 0.00935745 doing MySQL queries and 0.02938962 doing PHP things.
Please support our sponsor.
