diyAudio.com diyAudio Forums Archive > Top > Source > Analogue
Is it possible to mod my MMF-5 for 78s? - Click HERE for Original Thread
MannyE
I have had to listen to my 78s on a 1967 Magnavox console stereo for about 10 years now, and although it is fun to sit in the foyer and make martinis while Mel Torme belts out tunes, I would love to hear them on my real system and through some better speakers.
I was thinking I could either take the arm off the Magnavox and adapt it to the MMF-5 with a new armboard or something like that, then create a larger pulley for the motor....
any ideas welcome... should I just build a TT from scratch? I have been looking for an excuse...
I have access to old 1-inch video reels that would make a perfect platter.... and a motor from those very same machines.... plus the 1 inch tape itself as the belt....hmmmmm
But if I can just do a quick mod to the MMF 5 that would be OK. Plus I have always wanted a TT with two arms...
sreten
With a 78 turntable your problems are only just starting.
Using an old tonearm is not necessary with 78 styli available.
What do you plug it into ?
etc.. do a bit of searching on 78's.
:) sreten.
MannyE
Hi Sreten,
I plug the MMF-5 into a bottlehead foreplay, which in turn goes into bottlehead paramours. THe speakers are Ed's Horns. Phono is the little rat for now until I round out the system with the bottlehead seduction phono pre.
I will search 78, but I was specifically looking to mod the MMF-5.
Today, however, I sat in front of the TT and thought about how much of a shame it would be to mess with it now that I finally have it set up and sounding very well....
Plus...I'm getting jazzed on building from scratch.
I've got this itch to go to the granite places now...
sreten
Hi ME,
I just meant that there are lots of different EQ characteristics
to consider for 78's. Apparently using a 78 stylus on a MM into
a normal MM RIAA input doesn't work very well.
:) sreten.
Page generated in 0.022814035415649 seconds with 16 queries,
spending 0.00967455 doing MySQL queries and 0.01313949 doing PHP things.
