diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
new Renardson amp - Click HERE for Original Thread
dimitri
May I draw attention of the respected diyers to a new amp by Mr. Renardson
http://www.angelfire.com/ab3/mjramp/newamp2.html
The PCB will be available soon, if you need it, drop a note to Mr. Renardson
dimitri
And another amp based on the same principles from Czech
http://petrh.czweb.org/renardson.php
PMA
There is a cross-over distortion error correction in both schematics, listenning experience would be appreciated.
dimitri
I have simulated the output and would like to discuss it regardless of John Curl opinion:
”This fellow Renardson, is amazing! He re-invents all of audio circuitry, and then says that high power is not needed in the home”.
dimitri
Here are simulation results with R8 stepping from 100 to 1000 Ohm,
- transfer function of the output stage,
- current through nonswitching negative (lower) output device,
- transconductance of the output stage, please note the excellent linearity
millwood
quote:
I am curious about it too, especially why R9/11/15 are set up that particular way.
sss
does any 1 know how this distortion correction works?
dimitri
dear milwood and sss,
you can read there
or I can send additional info to you
PMA
dimitri,
you are probably using MicroCap7. Have you tried harmonic analysis? I would like to know whether there are or not higher order harmonics, and of what value.
Pavel
dimitri
Sorry for my slip,
instead "current through nonswitching negative (lower) output device"
please read "current through nonswitching positive (upper) output device"
Pavel, yes, it is uC7, I have not tried harmonic analysis, don't trust simulators... But it is not a problem
dimitri
Dear Pavel,
Could you please translate the abovementioned pages:
http://petrh.czweb.org/renardson_2.php
I tried to contact Petr Holub several times but failed :(
PMA
Dear Dimitrij,
I am sorry but I have not that much time. There is nothing new compared to original Renardson's publication.
Pavel
dimitri
I got several comments from the board members that the amp will have low disto only with active load, and with reactive loads it will be the same as ordinary class B.
Now Mr Renardson checked the 20kHz distortion with a parallel capacitance, and added the result to the test page. The distortion was higher than before, but the load impedance is lower, so some increase was expected, but there is no serious crossover problem.
capslock
Dimitri, what test page are you referring to? The angelfire page is not accessible.
dimitri
http://www.angelfire.com/ab3/mjramp/test.html
Nelson Pass
Reminds me of the bias circuit for the A40.
Page generated in 0.034848928451538 seconds with 17 queries,
spending 0.00852060 doing MySQL queries and 0.02632833 doing PHP things.
