diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
KYW's linestage (split from RIAA for life time) - Click HERE for Original Thread
Kuei Yang Wang
Konnichiwa,
quote:
Originally posted by Positron
Using a 100k with 100k resistor will severly lessen the high frequency response. The feedback circuit won't work on this problem. Look below at some figures of high frequency loss.
Consider a stage of gain of only 10, with 4pf grid to plate capacitance (two tubes in parallel so twice the gp capacitance) and no stray capacitance (very optimistic). I have computed (computer program) the -1db and -3db responses.
I presume you are refering to my suggested parallel 6SN7 Circuit?
I think you will need to check your computer programs a little.... They seem to be written by sciencce fiction writers.
Alternatively you need to change your logic, WRT NFB.
1) with 100k volume control set to midpoint
-1db = approx 6khz
-3db = approx 14khz
Not sure how you arrive at that, discounting stray the REAL results are actually with the volume control at midpoint (worst case) -1db @ 43KHz & -3db @ 84KHz, something I feel is tolerable for a Linestage to be used with CD Sources.
The variation of HF Response from worst to best case is minimal, with the volume set fully open (best case) the -1db point is @ 44KHz and the -3db point @ 86KHz, virtually no change from the "worst case" position.
I actually choose the circuit and recommended precisely because of the way it bahaves WRT to capacitive loading on the volume control, plus it's comparably low output imedance without using cathode followers outside a feedback loop. And of course because keeping the feedback loop around one stage only minimises the blatant sonic problems caused by using loop feedback around muktiple stages.
It makes a pretty good linestage, both subjectively and objectively, though I personaly would prefer an S&B TX-102, against which it can be easily compared BTW....
Sayonara
corbato
And this for the linestage. Just curious, cause as of yet I'm drawn toward Thorsten Sahib’s schematics. I really want to use those 6SL7’s and 6SN7’s
Kuei Yang Wang
Konnichiwa,
quote:
This linesatge will have a gain of over 20db. Combined with that Phonostage we are taliking overall around 100db gain. That is 30db too much gain for the usual 0.2-0.5mV MC Pickups and 50db too much gain for the usual 2-5mV output MM Pickups. It will also be almost 20db too much gain for any CD Player.
This would mean that your volume control will always be near the left endstop, the preamp will be xcessively noisy and suffer from poor overload behaviour.
For Preamps I'd recommend to consider the following issues in planning gain:
1) A CD player will output eaks of 2.8V with an average level around 14db below this, giving around 0.5V RMS for program material with 14db headroom.
LP's will be cut in the "energy" range of the music with up to 14db above the rated 5cm/s @ 0dB and a "bogey" MM Pickup outputs 2.5mV @ 5cm/s with a "bogey" low output MC pickup at 0.25mV.
This means we can have levels with a similar peak/average ratio than CD and similar average loudness if our MM Phonostage has a gain of around 46db and our MC stage of around 66db.
Most modern amplifiers will have an input sensitivity of around 1V RMS for nominal output. Older Valve Amp's and some rather badly designed modern Valve Amp's have a lower input Voltage, very few Amp's (such as my preferred 2-Stage Amp's with medium to low Mu triode drivers and DHT outputs) require a little more input.
This suggests that our Linestage will most of the time be required to attenuate, to have a littlke extra gain can help in marginal combinations, hence my preferred 6db Linestage gain.
So, the overall for a full function preamp with MC Input and the volume full up should be around 72db (the CAT matches that exactly) and for the MM input 52db (the EAR 834P which is a MM Phonostage aimed at directly driving integrated Amplifiers at CD level BTW has pretty much exactly this level of gain), in practice even these values tend to be 6db too high, leaving 6db gain reserve in the Phonostage and 6db gainreserve in the linestage, based on 1V Amplifier sensitivity. Any higher gain levels will cause serious system matching problems.
Sayonara
Positron
This design reminds me of the 15,000pf IC that was going to be marketed. "Hey it sounds good". Of course it didn't and the frequency response of the preamp it was connected was -3db about 7khz. "But it sounded good".
"I presume you are refering to my suggested parallel 6SN7 Circuit?
(It is an engineering program, you are way off, either in calculating or the thevenin circuit itself.)
(You obviously haven't thought things through. More on this below. Last string I mentioned there is a whole world you don't understand. You just demonstrated it again.)
-1db = approx 6khz
-3db = approx 14khz
(You better check your math again, or get the thevenin circuit correct. I also didn't include the capacitance of the volume control itself either.)
(In your dreams, and wrong as usual. You obviously don't have the correct thevenin circuit. Did you even bother to measure it? With the 100k grid resistor, the pot does make less difference, but 6 to 10k isn't much difference.
There are major differences between midpoint and control set to "max".
It depends on getting rid of the 100k grid resistor as mentioned indicated above, and then the frequency response is determined by the source Z (when when the pot is at max volume, wiper arm 100k from ground) and the capacitance. This raises the frequency response well above that of midresistance point, which is stated in my post. And remember, the FR deviation accumulates from circuit to circuit.)
(Compromise as usual instead of using a good design to begin with.
1st, capacitance does nothing good in this area.
2ndly, one doesn't need cathode followers, another stage, or the circuit you showed. There are ways around both.
3rdly, Using feedback around one stage. The problems of feedback depends on what follows, ICs capacitances, input Z of amp etc.
Do you even understand how these relate???
(Hope you don't give him a crappy PS design. This one measures and sounds crappy, if you like the highs dissappearing.)
_______________________________________
Yes, the gain does change the miller capacitance, but not enough to raise the poor frequency response of the network out of the audio band. Halving the gain to 5 only doubles the FR; thus still very poor.
And time delays in the feedback. This time delay depends on the Capacitance of ICs, and tube input capacitance of the amp etc. Changing Z input of the amp, changes feedback ratio etc., which changes the miller capacitance etc.
Mediocre design.
thoriated
Hi, Ashok -
Can you lose C1? It doesn't seem to be adding that much and I'm personally allergic to 'lytics in the signal path:). Perhaps it might be advantageous if C3 could be made larger to minimize lf phase shift and rolloff, also.
Kuei Yang Wang
Konnichiwa.
Hmmm. My results come from P-Spice and cloesely match those I observed on a real version of this stage.
Last time I mentioned that you deliberatly claim unrealistic results and consitently fail to show an appreciation of basic electronics. I again observe the same thing.
My math for the Circuit I presented is correct. Please build teh circuit if you do not believe basic electronics and physical laws hold sway, you will be thought that still do.
Nor did I, however most modern volume controls show very little local capacitance (mostly because the are largely made from plastic.
How would you know, as you obviously fail to even appreciate how the circuit works.
Sorry, NOT IN MY CIRCUIT.
Non of which has anything to do with the circuit I presented. So we are again at the game of using numbers that while having some relation to the context are completly unrelated to the topic at hand. Well, nothing new.
The compromise was set by the basic requirements stated. We may argue if my circuit works better in reality, within the stated limitation than yours - oopps, I forgot, you don't suggest circuits, you only try to put other peoples suggestions down without even comprehending what is being suggested.....
Absolutely.
So, between my posting the circuit (which was previously build with ECC88 and a slightly higher gain but also tested with the 6CG7 which is a noval 6SN7) you build the circuit, managed to have an exhaustive listen, to test the crcuit on the bench and posted your results. All within 5 Hours. I am mightly impressed. I cannot compete with that. However, when you build the ciorcuit you must have made a few wiring mistakes (not to worry, even happens to me when I'm rushed) and as a result your tests seem to have gone a little astray.
Or maybe you did not test the circuit? Maybe you just used what little of electronics to try to understand and abysimally failed to do so?
Mediocre design.
Well, why don't you suggest one that is demonstrably better? I don't mind. This is a free for all. But please ensure to provide sufficient wide bandwidth, low output impedance and distortion. It's not like I'm stopping you to present your designs, which are so superior to uthose from the other great unwashed.
Sayonara
thoriated
Can you expand a bit on the comparative sonic advantages of each relative to the other? The TX-102 seems to be a bit pricy, maybe justifying a little tweaking of the non-magnetic option.
TIA -
Kuei Yang Wang
Konnichiwa,
quote:
Well, various comments etc are in this thread:
http://diyaudio.com/forums/showthre...8613#post348613
I'll leave it at that.
Sayonara
Positron
"Konnichiwa.
<Really, well you didn't use the proper thevenin circuit did you.>
<Interesting as I am the one who graduated number 1 in my Electronics Engineering class and you don't have a degree, do you???? Of course, you skipped over that one last string, didn't you. And you lost pitifully last string, remember.
Caught you stating you had Way more than two years into tubes, but your own bio stated you had only approx 2, remember? You've have been caught numerous times posting inaccurate positions I made, remember. Isn't that called lying?
By the way, do you know some more of the other weaknesses of "your" circuit? If you can't answer this, then who is the novice?>
<Well, obviously, then you don't know the BASICs of how to thevenize a circuit. And I am the novice? >
<Where did you come up with that reply? If you had measured some famous controls, the capacitance is fairly large do to the shielding of the metal case. Caught yourself again.>
<Caught yourself again. And who pointed out the major weaknesses of the circuit? Me. Can you explain the ones I haven't brought up yet? This will tell if you really understand your circuit.>
<Unfortunately, there is.>
It depends on getting rid of the 100k grid resistor as mentioned indicated above, and then the frequency response is determined by the source Z (when the pot is at max volume, wiper arm 100k from ground) and the capacitance. This raises the frequency response well above that of midresistance point, which is stated in my post.
<If you understood the circuit as you claim, you would have answered differently.
At midpoint of the pot, phase shifting occurs well below 20khz. It is easily heard on a system.>
<No, there are many circuits I don't comment on here. But when I see a completely idiotic circuit, and the person wants something really good, well.... Let's see if you can find some more problems with this circuit. By the way, one can build much better with his list of parts, wider bandwidth, very low distortion, low output Z.>
Absolutely.
<When were you going to tell him about the problems I have mentioned and others I haven't yet?> Can you explain more other than "absolutely"?>
<Typical response. I have been designing for decades. I have used 6sn7a etc in all sorts of designs, including the one you presented, and have some in my stash right now.>
<Well, if you understood the circuit, and how it sounds, as you claim, you would have known all the weaknesses and flaws and could have recommended a better design. (Again, if you understand the basics, you explain the other problems this circuit has, that I have not yet mentioned. If you don't, everyone will know your novice status.)>
Mediocre design.
Well, why don't you suggest one that is demonstrably better? I don't mind. This is a free for all. But please ensure to provide sufficient wide bandwidth, low output impedance and distortion. It's not like I'm stopping you to present your designs, which are so superior to uthose from the other great unwashed."
<Sure, I am just going to give you my designs, which took years to develop. typical shill comment. :whazzat: >
<Ok, keep away from CFs, work much more on the power supplies, and use low output Z, high bandwidth, low distortion tubes, the best brands sonically too.>
Kuei Yang Wang
Konnichiwa,
Well, it seems I made my usual error and actually assume that those who claim to understand electronics are sufficiently competent not talk complete loblocks (as they say on Planet anagramia) and hence will make some sense and the rest doesn't want to know anyway. Seems I'm wrong.
So hence, let's evaluate, strictly on paper and in a simplified form the 6SN7 parallel linestage.
First, open loop we have an anode impedance of around 8k. Paralleled this gives an internal impedance of 4k and with a 10k Load a stage gain of 12.6, this comes from comparing the Load (22k//10k) Rl and the internal impedance of the stage (4k) Ri as voltage divider and reducing the Valves Mu by this factor as:
Gain = Mu/((Rl+Ri)/Rl)
Now we can calculate the Miller capacitance and using this also the input capacitance. For average Valves my Datasheets list 3.3 & 3.5pF as Anode-Grid Capacitance, so both systems in parallel show 6.8pF which will be "amplified" by the stage gain, 12.6 to give a virtual 85pF input Capacitance between Grid and Andode. Adding the other parasitic valve capacitances we get a rounded 100pF capacitance if good quality (ceramic) sockets are used and the layout is sensible.
Now we can calculate the relative impedance of the gridnode to obtain the OPEN LOOP bandwidth (note that this a looped feedback amplifirer stage).
At the worst case (volume control at -6db setting) the 100k Volume control will present around 25k output impedance, to this is added the 100k Input resistor of the inverting, looped feedback amplifier. In parallel to this overall 125k impedance is the feedback loop and internal impedance of the circuit, so basically 244k. In parallel this gives a impedance of 82.6k.
If we combine the 82.6k and the 100pF we get a timeconstant of 8.26uS or a -3db point of 159115/8.26=20KHz.
So, OPEN LOOP we have a -3db point of 20KHz in the worst case scenario. This frequency is shifted upwards in the usual manner as discussed by Harold Black in the 1930's by the diference between the Open Loop gan and the closed loop gain.
In my case the closed loop gain is 2, so we have around 6.3 or 16db feedback factor, so in theory and not accounting for some of the parasitics I include in my P-Spice simulation (such as the 1nF output load of the 10k/1nF IEC Load) we have theoretically a closed loop -3db point of 126KHz under worst case conditions, but only if there is no capacitive load. My simulations assume 1nF capacitive load and hence are less favourable.
Let's also work out the apparent output impedance of the Linestage. WE have a 22k Load in parallel with a 4k internal impedance, giving under open loop conditions 3.4KOhm output impednace. This will be reduced (again) by the feedback factor giving us theoretically around 530 Ohm output impedance.
A last check would be how much the difference between fully open and worst case setting on the volume control is. Using above Methode we now have 100k//244k to give 71k effective impedance at the grid node. This gives a 7.1uS timeconstant or 22.4KHz open loop -3db point and closed loop theoretically a 141KHz -3db closed loop.
This concludes the current EE101 lesson for those who wanted to know and those who obviously slept through EE101. We thank you for your attention and suggest that everyone her or himself evaluate designs themselves, using sensible methodes instead of listening to people who obviously lack basic analytic skills (or deliberatly distort the truth - I leave it to the audience to decide which takes place).
Sayonara
Positron
Too bad you have to resort to such negative tatics. But the important thing is that the truth is being exposed.
First off, he Again refuses answer the question of education. Not surprising since, as we shall see below, he only has a couple of years experience with tubes and the design he presented shows it. Let's take a look.
<"If we combine the 82.6k and the 100pF we get a timeconstant of 8.26uS or a -3db point of 159115/8.26=20KHz.">
Actually 17.5k, using the electronics computer program, and the
-1db point is only around 8.7k (we will use your own figures), Very poor open loop response indeed. Similar to open loop SS designs with feedback, esp in the old days.
The only reason the open loop FR is even this good is because of his feedback scheme and the need for the 220k in the circuit. Of course Thorsten needs to increase the open loop FR response. Very messy circuit indeed. Remember how delicate music is and how easy it is to upset things sonically.
You finally got around to mentioning the 16db of negative feedback to try to bring up the response and lower the output Z. Real brilliant design there. But there are more problems indeed using this design. Can you figure them out?
By the way, my design has an Open loop FR of over 100khz (pot midpoint) with 100pf/100k load, extremely low distortion, and output Z pretty low. All without 16db of feedback to screw the sound up!
<"This concludes the current EE101 lesson for those who wanted to know and those who obviously slept through EE101. We thank you for your attention and suggest that everyone her or himself evaluate designs themselves, using sensible methodes instead of listening to people who obviously lack basic analytic skills (or deliberatly distort the truth - I leave it to the audience to decide which takes place).">
Not a smart comment Thorsten. You already got caught in the last string trying to hide the perks/compensation you receive under the table (I had to ask you twice before you would spill the truth, or partial truth, remember; while I volunteered mine). You also distorted my positions too. And now the comment above. I have always found that deception and unethical behaviour doesn't lead to being trusted?
By the way, you only mentioned the basics, including the 16db of feedback. Now explain the rest of the problems with the circuit and the feedback.
Vortex
Corbato,
have you seen THIS site?
Kuei Yang Wang
Konnichiwa,
A computer program that arrives at 17500 when dividing 159115/8.26 seems rather inacurate.
And if you mean to say that your program arrives at a different analisys, you should be able to point out the ommisions in my calculations (which where done primarily for breviy and clarity), that assuming of course that you actually understand what is going on, which based on your comments so far I am forced to seriously doubt.
Well, number one, the use of Feedback is an inherent design feature. Negative feedback is a design tool, just like any other. It needs to be understood to be used correctly. Only those who fail to understand it take refuge to comments of "feedback is bad" as an absolute.
In my case negative feedback is the primary tool to achieve low gain while using an active stage and avoiding followers. The frequency response and low output impedance are the redsult of doing things that way. One could have used an output transformer to achieve low gain, low output impedance and wide bandwidth, the original request was not to use Transformers, so non are used.
Thank you for your compliment.
There are no PROBLEMS if the circuit is implemented as suggested and operated within it's design parameter limits. We may argue about the way this circuit sounds or not, which would require after all experience with the circuit and it's sonics, which you seem to still lack.
A design, for which you make any number of claims which cannot be verified (unlike the ones for mine) as you fail to share it. I will simply put these parameters down to your usual baseless claims as we have seen in past discussions.
If the use of negative feedback "screws up the sound" the implementation of negative feedback was incompetently done. So you may wish to re-evaluate your views on negative feedback as a design tool.
I would consider making deliberatly misleading statements (eg claiming a circuit that has illustrably a frequency response of -1db @ > 40KHz has one of 1db @ 6KHz) both unethical and deceptive.
Of course, it seems you call that behaviour ethical and truthfull. I must insist that this is where we part company.
How about you do so, making sure your math is actually up to scratch and your computer program can at least divide correctly and you math is based on reality not wishful thinking.
Sayonara
Positron
<"quote:
And if you mean to say that your program arrives at a different analisys, you should be able to point out the ommisions in my calculations (which where done primarily for breviy and clarity), that assuming of course that you actually understand what is going on, which based on your comments so far I am forced to seriously doubt.">
Your figure is only approx. I actually measured them, but of course measured stray capacitance too, which we both didn't include when starting. But let's give you the benefit of the doubt. The open loop response is still -1db at 10khz and -0,5db at approx 5khz. Still very poor.
<"Well, number one, the use of Feedback is an inherent design feature. Negative feedback is a design tool, just like any other. It needs to be understood to be used correctly. Only those who fail to understand it take refuge to comments of "feedback is bad" as an absolute.
In my case negative feedback is the primary tool to achieve low gain while using an active stage and avoiding followers. The frequency response and low output impedance are the redsult of doing things that way. One could have used an output transformer to achieve low gain, low output impedance and wide bandwidth, the original request was not to use Transformers, so non are used.">
Well, give me a wrong way to use the feedback in a single stage preamp. It isn't hard to do correctly, or at least as best as is possible.
<"There are no PROBLEMS if the circuit is implemented as suggested and operated within it's design parameter limits. We may argue about the way this circuit sounds or not, which would require after all experience with the circuit and it's sonics, which you seem to still lack.">
Well, that sounds suspicious to me. You don't know of any more problems?
And I built the circuit decades ago, so another inaccurate claim. The circuit is only ordinary at best.
<"Originally posted by Positron
A design, for which you make any number of claims which cannot be verified (unlike the ones for mine) as you fail to share it. I will simply put these parameters down to your usual baseless claims as we have seen in past discussions">
Actual measurements Thorsten. I am certainly not going to give you a schematic to copy and waste decades of private research.
By the way, I just recently got the latest review from BFS, who accepts no kickbacks or advertising, on my preamp. What reviews do you have on yours??
If the use of negative feedback "screws up the sound" the implementation of negative feedback was incompetently done. So you may wish to re-evaluate your views on negative feedback as a design tool.">
So tell me how to do it wrong?? What you have done is very elementary, my dear watson.
Of course, it seems you call that behaviour ethical and truthfull. I must insist that this is where we part company. ">
Interesting since you were the one who refused to devulge your unethical behaviour until I asked twice.
I probably could have brought up the point directly, that the open loop response was very poor. But I wanted to find out if you actually understood the circuit, and for you to mention this problem. If I mentioned it upfront, you could have easily slid by. Frankly, I didn't think you even understood the basics. You do show some knowledge of design though, I will give you credit for that.
How about you do so, making sure your math is actually up to scratch and your computer program can at least divide correctly and you math is based on reality not wishful thinking.">
Remember I am finding out what you know; as you claim, from your above post, to be teaching me.
I wouldn't have graduated No. 1 in my class if I didn't know my stuff. I am not going to give you a free education. It took me alot of work and time.
If you wish to exit this conversation, go ahead. No problem.
ps. Go fighting Illini
Kuei Yang Wang
Konnichiwa,
Do not distract from the issue.
You measured them. Right. May I ask when you build the circuit? And could you then illustrate the change in response with volume control settings you calimed earlier? Any comments on the sound?
On another line, would you mind illustrating in what sense an open loop response of -3db @ 20KHz in a looped feedback Amp (single stage) is "poor". It is more than adequate for the purpose. The open loop response is a direct result of a number of design choices.
It would be easy to change the open loop response to a much wider one by lowering the impedance values in the feedback setting circuitry and by using a lower resistance volume control. If we (for arguments sake) lower all values by a factor 10 we can easly achive a ridiculously wide bandwidth, which has no advantage whatsoever (sonically or other) and introduces a number of other problems.
It is my experience that a well implemented and sensibly set bandpass behaviour is preferable in linestages, arguably a sentiment open to discussion, however I usually follow my own design requirements when designing something.
Is the above your opinion or are you stating a fact? If you are stating a fact, would you mind illustrating WHY applying loop feedback to achieve low gain and to take advantage of the stages excess gain to improve linearity and lower the outputimpedance is "a wrong way to use feedback"? Maybe you would like suggest the "right" way to use feedback?
At any extent, you may notice that we are now outside the realm of factual performance (unless you can illustrate that the laws of physics have recently gone on annual leave) and in the realm of design preferences and how they relate to sonical performance.
You build a Circuit I published here a few days ago DECADES AGO, with identical resistor, cpacitor and other values? Interresting feat. I now would also ask for plans to your time machine, I could use one.
I will readily admit that similar circuits have been around for ages and some of the best sounding commercial preamps of the last two decades used variations thereoff. So it surely cannot be THAT BAD....
<A design, for which you make any number of claims which cannot be verified (unlike the ones for mine) as you fail to share it. I will simply put these parameters down to your usual baseless claims as we have seen in past discussions">
Well, first, are your actual measurement independently verified?
Secondly, the design I presented is strictly DIY, not commercial> A design based around my ideas and parts mostly designed by me is the MF Audio Passive Preamp, the Bent Audio Noh and the DIY Hifisupply Django, plus there are other Preamps using the same core (S&B TX-102) in both the DIY and commercial domain.
Many reviews by many individual exist and they tend to agree in the largest part that the S&B TX-102 based passives outperform ANY active preamp these individuals have tried and also most/all passive linestages from other sources. That is good enough for me.
First, I never claimed that what I did was NOT elementary. As to "How to do it wrong"? For starters loop feedback around several stages and in circuits where there is more than one dominant pole and have an open loop response (-3db) that is substantially narrower than the desired signal bandwidth. But you should know that, if you are 1/10th as good as you claim to be.
WHAT unethical behaviour? Giving free advise when asked for it? Providing my designs for all to use who would like to do so? Pointing out the mistakes in basic electronic theory application you make when leveling irrational criticism at designs I suggest?
Correction. The open loop response is poor in your considered opinion, whereas in my case I consider it adequate and a good compromise between a number of conflicting design requirements. We can argue endlessly about what is the better compromise, the choice is in the ear of the beholder.
Nice excuse for incompetence. It would ring truer if you had less of a history of completly ballsing up on basic electronics. I took the time yesterday to review a decent number of posts by you. I rarely seen as many mistakes in basic things from anyone having at least basic competence in electronics. I had more than a few good laughs on your account.
I'm honoured.
But truth is, what is the point if an illiterate peasant pays backhanded compliments to Newton?
I notice. But don't expect much else from here.
Well, it seems that you spend a lot of time and work to fail to know even the basics of electronics. I shall take in the next few days take the time to illustrate this a bit further (I'm actually going to enjoy that) and collect your various psotings of great wisdom over the last few month which demonstrably show an appaling lack of being able to apply basic logic and evaluating basic electronic circuits. And not forget the public (re) posting of some of the olded urban legends in the book, that was priceless.
Sayonara
EC8010
Gentlemen, would it be possible for one or both of you to post diagrams of what you are discussing? Otherwise, entertaining though it may be, your exchanges are beginning to resemble a pantomime ("Yes, I did" - "No, you didn't").
With the aid of diagrams, a spirited design discussion would be most useful for less experienced members...
Kuei Yang Wang
Konnichiwa,
quote:
I have posted what I am discussing within this thread, at this post:
http://www.diyaudio.com/forums/show...3015#post353015
As you are aware from the discussion the other guy (I refuse to use "Gentleman" in the context) has repeatedly refused to share anything, whatsoever, prefering sniping from the sides at those more willing to share (and possibly more able than he is?) to actually contributing anything useful.
I am sorry, but if someone posts utter nonsense IN CRITIQUE to contributions by me I am unwilling to let this go. I don't much care in other contexts.
As pointed out above, the aid of such diagrams is indeed provided, at least for my side of the argument.
Sayonara
EC8010
My mistake; I failed to spot Kuei Yang Wang's diagram back in Post #8.
Peter Daniel
Although the RIAA and Linestage might not, this disusion has good chances to be for life time;)
Kuei Yang Wang
Konnichiwa,
quote:
One rather hopes not. I for one am well sick and tired of this whole thing (and very irritable anyway as it's financial year end where I work). I got better things to do. Where the technical side is concerned I have made any possible point (and scored them all and easily) as for ethics and morals, i leave that to gentlemanly reader to decide.
I think however I will not want to miss putting together my little "positronic non-sense" post (as compensation), but that will go into a seperate thread.... ;-)
Sayonara
Positron
Well, we can point out some more distortions, misinformation and maybe an outright lie from Thorsten. Of course he continues to evade and sneak around, trying to avoid the questions I have put forth to him. But this time he even puts down his own system. Read the details below.
The FR is as I stated, you cannot sneak out of this one. It is-.5db around 5khz, -1db at approx 10khz, very poor. As before, I built this circuit and tried it years ago. It beats some SS designs.
In your dreams Thorsten. You can't sneak out of this one. I already asked you to explain it several times, but you can't.
<It would be easy to change the open loop response to a much wider one by lowering the impedance values in the feedback setting circuitry and by using a lower resistance volume control. If we (for arguments sake) lower all values by a factor 10 we can easly achive a ridiculously wide bandwidth, which has no advantage whatsoever (sonically or other) and introduces a number of other problems. >
First. Only after I mentioned it in my post do you now mention opening the bandwidth.
Second. Then why didn't you design it with better open loop response (except for interference problem areas) to begin with. Afterall, according to your own words, it doesn't make any sonic differences. It would at least look better on paper to the critics.
Actually, there are differences between the designs, but you don't know it. You lost again Thorsten.
****You cannot discern any sonic differences between the two feedback preamps with either wide and narrow open loop bandwidth. Way to go Thorsten, cut your own system down. Thanks for the help Thorsten.
<It is my experience that a well implemented and sensibly set bandpass behaviour is preferable in linestages, arguably a sentiment open to discussion, however I usually follow my own design requirements when designing something.>
So how can you tell when your system can't reveal the difference between two feedback preamps with different open loop FRs. Does either sound like a straightwire with gain?
Looks like you just made up another story.
<quote:
Is the above your opinion or are you stating a fact? If you are stating a fact, would you mind illustrating WHY applying loop feedback to achieve low gain and to take advantage of the stages excess gain to improve linearity and lower the outputimpedance is "a wrong way to use feedback"? Maybe you would like suggest the "right" way to use feedback?>
You can't even show me a wrong way to connect negative feedback to your circuit. I have asked you several times to explain the inners of feedback but you couldn't, so don't ask me now. And you are Newton??
<You build a Circuit I published here a few days ago DECADES AGO, with identical resistor, cpacitor and other values? Interresting feat. I now would also ask for plans to your time machine, I could use one.>
Interesting that what you condemn me of is exactly what you did in past strings, condemn my components, tubes I use, and me without ever hearing them in my designs. You sound like a shill.
The difference is you have only 2 years experience vs 44 years for me. So I have much more accumulated knowledge, listening experience, testing many more designs (each of which I have used a vast number of parts etc) than you have. You can't sneak out of this one Thorsten. Nailed ya again, Newton.
How about some names hotshot. And how close are the designs?
<Actual measurements Thorsten. I am certainly not going to give you a schematic to copy and waste decades of private research.
Of course this is how a typical con artist works; trying to steal a design instead of paying for it. Typical shill attitude.
<Well, first, are your actual measurement independently verified?>
Where is the review Thorsten?? Come on now. Stop hiding.
By the way, there are many over the years who have seen my testing, actually watched.
So what is your point? Does it sound like a straight wire with gain? Have you even actually tested it for such?
The question was in your design, not a two stage design or multiple poles. You can't seem to answer a simple question. Are you simply quoting from a book in front of you? Otherwise why mention a completely different circuit? That is it, he has someone or book in front of him.
<I would consider making deliberatly misleading statements (eg claiming a circuit that has illustrably a frequency response of -1db @ > 40KHz has one of 1db @ 6KHz) both unethical and deceptive.
Interesting since you were the one who refused to devulge your unethical behaviour until I asked twice, and constant lies and deceit, including the ones in this string I have caught you in. And you are saying I am unethical because I tricked you into divulging a 16db feedback you were trying to hide?
<WHAT unethical behaviour?>
Everyone who has been reading these strings have seen the lying, deceit, and unethical behaviour you have consistently shown. Don't get mad at me when your world collapses on your head. You did it to yourself, with no one else to blame.
<Correction. The open loop response is poor in your considered opinion, whereas in my case I consider it adequate and a good compromise between a number of conflicting design requirements. We can argue endlessly about what is the better compromise, the choice is in the ear of the beholder.>
Wrong again Newton. The straightwire with gain is the standard, not your opinion Newton, and not mine. And the open loop, or closed loop response of the preamp sounds poor by that standard. You can't sneak around that; lost again Newton.
<Nice excuse for incompetence. It would ring truer if you had less of a history of completly ballsing up on basic electronics. I took the time yesterday to review a decent number of posts by you. I rarely seen as many mistakes in basic things from anyone having at least basic competence in electronics. I had more than a few good laughs on your account.>
Why didn't you give an example now? Bring it on hotshot. Of course we both know you are a liar and shown you know very little.
Very interesting since you didn't understand the problems with your preamp design until after I mentioned them; and you still can't go any deeper into the design. Keep making a fool out of yourself Newton.
<But truth is, what is the point if an illiterate peasant pays backhanded compliments to Newton?>
You're Newton?? You can't even answer indepth questions about your own preamp, know how to apply feedback wrongly in your design. I had to get you to admit to the 16db of voltage feedback you were trying to hide if you even knew about it.
Everyone who sees this post will forever link you to your own Napolean complex, total arrogance, and total absurdity, besides total stupidity. Wow! And a audio mag let's you review??? Of course do they know you are being compensated under the table, and tried to hide it? Isn't anything about that unethical... "<WHAT unethical behaviour?" ...the answer to your above question that you try to hide time after time?
<How about you do so, making sure your math is actually up to scratch and your computer program can at least divide correctly and you math is based on reality not wishful thinking.">
I notice. But don't expect much else from here.">
Of course we all know you have had help or bluffing your way through.
<Well, it seems that you spend a lot of time and work to fail to know even the basics of electronics. I shall take in the next few days take the time to illustrate this a bit further (I'm actually going to enjoy that) and collect your various psotings of great wisdom over the last few month which demonstrably show an appaling lack of being able to apply basic logic and evaluating basic electronic circuits. And not forget the public (re) posting of some of the olded urban legends in the book, that was priceless.>
Why didn't you bring one forward? Lying again are we? And are you going to misstate my positions again like I caught you doing in a previous string? Remember, completly the opposite what I had stated. Isn't that called a bold face lie? Unethical if I remember correctly.
But don't blame me when you continue to sink yourself.
Who is going to believe your reviews anymore??
Bye bye Newton
Kuei Yang Wang
Konnichiwa,
First the one that really had me in stitches:
http://diyaudio.com/forums/showthre...1399#post341399
"Please read. Post #1
Although not audio related, I thought I would relay this from my sis, a school teacher.
Subject: Police Warning
POLICE WARNING,
ONE OF THE OFFICERS WHO WORKS WITH THE DARE PROGRAM HERE IN SHREVEPORT HAS PASSED ALONG THE FOLLOWING WARNING AND ASKED THAT IT BE SHARED WITH ALL DRIVERS. THIS IS AN EXTREMELY SERIOUS MATTER. "
Following on from that is a rather old hoax, I mean not even something current, but ancient, from around 10 Years ago.
http://www.snopes.com/horrors/madmen/lightout.asp
And prior to being moved "off topic" this was actually posted in the "Tubes" section.
But of course just because someone does not have the common sense to spot ancient hoaxes does not mean he is bad at electronics. So, any really basic gaffes there? How about this:
Someone asks about a sonic problem with his kit preamp:
http://diyaudio.com/forums/showthre...8057#post348057
To the rescue our intrepid positron, exposing medocre design where he sees it:
http://diyaudio.com/forums/showthre...8996#post348996
"Hi James,
Looking at C18 (and R16, 10, 11), no wonder it sounds thin. Should be much larger if you want descent lows and flesh on the "faces". The other two caps also form high pass filters too."
Let's see, the circuit around the second halve of V1 is a bootstrap follower, a circuit well known to anyone who has done any significant work wth valve equipment. It's key feature is a very high input impedance, theoretically infinity, in reality several times the actual value of R10. HOWEVER, even IF R10 was determining the LF cutoff of the highpass, would that be a problem? If we multiply 1000k with 68nF we get a timeconstant of 68,000uS, equal to a frequency of around 2.33Hz.
No wonder it sounds thin, the LF output is 3db doen at 2.33Hz (except it isn't, it is 0.3db down at 1Hz!!!! - [per P-Spice which on such things is jolly close]). And of course he cannot omit a cheap snide snipe either:
"If I remember correctly, Velleman is rather inexpensive, so you may not be able to do alot without major modifications."
Read "You bought cheap ****, you will have to live with it".
Luckily enough some others where there to correct him before the poor guy james run away with this piece of "good advise" and would of course find no improvement whatsoever. So, okay, Positron admits he was wrong (heck, he was at least a magnitude or two out...), but plots revenge, after all, it must be a RC higpass that causes this....
So we get:
http://diyaudio.com/forums/showthre...9059#post349059
"R15 should be increased, will help the bass response and add "flesh" to the voices. Might first try a large value, say 220k and see if it is ok or is too full. If to full, then back off the value till it satisfies your tastes. "
Hmm. At first look R15 looks a little low in value. And indeed, it would not be my choice to achieve what the Velleman designer has done here in that particular way. However, Positron does not assert that the problem is the main effect caused by R15 being low in value (and which is at least partly the reason for the "washed out, bright sound"), but he asserts that the low value of R15 cuts the Bass.
Well does it? If we multiply 4700nF with 5.6 Kohm we get a 26,320uS timeconstant. This corresponds to a 6Hz -3db point, but because we have this whole thing attached to a bootstrap follower and not a normal cathode follower the actual -3db point is at 5.5Hz (per P-Spice which on such things is jolly close) and at 20Hz the LF rolloff is -0.3db (per P-Spice).
Even with an added external 10K load the -3db point is at 8Hz and 20Hz is only 0.6db down. Hardly spectacular stuff, but miles better than pretty much any funloving loudspeaker you care to name.
I think the "R15 is too low and hence thins out the bass" brainstorm can be safely put to rest. Now MAYBE, just MAYBE Positron actually caught on what really happens and just wants avoid showing how smart he is and hence suggest to do the right but claims the wrong reasons?
Well, he has the last word in that thread:
http://diyaudio.com/forums/showthre...9488#post349488
"R15 is the real problem, much too low. Creates a high pass filter and thus limits bass and extends sonically to the midrange sounding thin."
Well, clearly, he has not cottoned on as to what is happening. He insists on the "Highpass set at too high a frequency" to the last. Well at least he is consistent.
More pearls of Positronic wisdon another time. At least now I know what the guy meant when he quipped "Artificial inteligence is to real intellgence like artificial flavourings to real flavours".
Sayonara
PS, the solution to the riddle of the bright sound?
Have a look at what heavily loading a cathode or bootstrap follower does to the distortion pattern (especially complex IMD).
The Velleman designer deliberatly loads this stage down to get a certain sonic effects by raising distortion, sadly doing it the way it is done here also leads to other sonic effects, namely usually a somewhat less than pleasant sound.
So, loads of points for effort positron, zero points for circuit analysis - my old tutors would so much have failed you in EE101, it is not even believable.
fdegrove
The CF on it's own wouldn't survive any real world testing regardless of the size of R15.
Whenever it's required to deliver some current into a load it will inevetably collapse trying to steel from the anode follower.
This is one type of CF that should be avoided to drive difficult loads.
Loading it down already, hence drawing an almost constant current makes it look better in isolation but perform even worse in the real world as it will now have nothing left to "steel" from.
Add to that the bootstrap positive feedback_ which you can really do without here_ and you really wonder what on earth they were trying to achieve.
To add further insult to injury, a quick look at the distortion spectrum of a garden variety ECC82 will reveal it's already anemic condition to the point that it almost always sounds shrill and lifeless.
In the case of the Velleman circuit_ I'd like to know that Belgian designer, or maybe not_they made every conceivable effort to make matters worse.
So real estate permitting; get rid of the bootstrap by tieing R10 straight to ground, change R15 to about 100K and maybe, just maybe it would be a little better.
At least that's what I'd do facing a crying customer.:bawling:
Cheers,;)
DougL
Kuei Yang Wang;
Konnichiwa,
I always learn something from your contributions.
The design you presented had a couple of features that I wanted to ask about.
It looks like each tube is only biased for about 110 Volts and 3.2 Ma current. This is very conservative.
Also, I notice that with 16 DB feedback, the maximum voltage swing in the negative direction is only about 8V.
The Analysis is via Tube Cad, which seems good for quick approximations.
Respectfully;
Doug
By the way, I will Propose something in the other thread.
Only fitting.
Please feel free to comment.
Kuei Yang Wang
Konnichiwa,
quote:
Yes. You will find that in most cases my operating points are VERY conservative. Rare NOS valves last longer that way and to my ears sound better.
I am not sure how you arrive at that conclusion. The maximum output voltage swing remains what it is prior to applying negative feedback, which is well past 20V RMS. Remember, this is an inverting amplifier, where the grid voltage is in effect the "error voltage" between the ideal "zero" with an amplifier having infinite open loop gain and our real Amplifer. Unlike some other topologies shunt feedback as seen here does not compromise the input dynamic range, it is increaed in effect by the feedback factor.
Not sure how accurate Tubecad models this specific topology. I don't have it or use it, having learned P-Spice ages ago and thus being non too willing too change. I have fond P-Spice to be usually "very close" in many cases, the exceptions being such items as grid current and other "extreme non-linear" operation conditions.
Sayonara
Positron
Well, as usual, you made a big fool out of yourself. Let's take a deeper look.
The first, a warning, not audio related:
First off, I love my tube buddies and wanted them to be warned. They might not see the post in another venue. Secondly, you are laughing about something that is real. I have a friend whose son, a Chicago postman, who was shot several times on a busy street by someone jumping out of a car, in broad daylight. It was an initiation for a teen. He survived. By the way, the dads daughter is a police officer up that way and things are pretty nasty. If you think this is funny, that is your problem Thorsten. I was concerned for my friends. I don't keep up on hoaxes. Your comments really show what you are really like. What a shame.
Now let's look to the audio postings.
"Hi James,
Increasing C18 will help lows but be careful of possible motorboating from weak power supply design. If this happens, will have to lessen value of C18. Would try to give it 6db leeway in this regard.
Also might try getting rid of C17.
Take care.
Steve"
"R15 is even worse, 5.6k?! Increase it alot, even to 220k or more if desired without harm, and see how it sounds. Shouldn't be any motorboating problems as this resistor is "out" of the circuit design that could cause motorboating.
Touch up C18 later, if you need to.
Take care.
Steve"
"Dear Frank,
I think you are correct. Sorry about the mistake.
Is C18 68000pf? Looks like it to me. If so, it should be ok.
Thanks for catching my mistake Frank.
Take care.
Steve"
Take care.
Steve"
1) So first off I don't see a page 2. Ok, now: "Read "You bought cheap ****, you will have to live with it"? I don't see where I said that. I was trying to be kind. That sounds pretty harsh to me. I wouldn't have offered suggestions to improve the bass, and mids if I didn't think it might not work.
Secondly, changing a cap is rather major, esp to a newbie (if he is one). He might also remove C17 which is major, get into the chassis project. These aren't minor like changing a tube. However, if he took it that way, my sincere apologies to James.
2) Where did I make the comment "No wonder it sounds thin, the LF output is 3db doen at 2.33Hz". I don't see this either on my posts. Does anyone else?
3) The schematic was hard to read, and I didn't want to cause waves with Frank, he is valued by me. So I let it go. But C18 is really too small at .068uf. Why? Well, if Thorsten had actually done any testing, and new tubes as he says he does, he would have known the reason.
A) "It's key feature is a very high input impedance, theoretically infinity, in reality several times the actual value of R10."... is not necessarily true.
There is a very, very, very small amout of grid current, varies by tube, the remnence of contact potential and impurities, depending on the tube type and manufacturer, and C18 is rather small to handling this problem. As a result, depending on the tube, the sound changes not only the bass, but the midrange and highs too. I have seen this problem, but you didn't know this with your lack of experience. If the capacitor was a larger value, the tube would have more leeway in regards to grid current variation in production, so generally no worries unless the tube checks grid current on a tube tester.
B) The midrange/high problems could also be the construction of the capacitors. Thus several aspects can be in play.
However, looking at the circuit closer, which I apologized for not doing, revealed R15 to be a/the major problem. In fact R15 is ridiculiously low for high fidelity without even doing any math. A total screwup in design, for accurate reproduction that is. I have to admit I didn't look twice at this part of the circuit as no one pulls a stunt like this, at least I thought not. Thanks to Fd for making me take another look at this design. This low value not only loads a cathode circuit, but also just about any plate output circuit as well. It is suppose to be high fidelity, it shouldn't have had this low value.
<"Luckily enough some others where there to correct him before the poor guy james run away with this piece of "good advise" and would of course find no improvement whatsoever. So, okay, Positron admits he was wrong (heck, he was at least a magnitude or two out...), but plots revenge, after all, it must be a RC higpass that causes this....">
As usual, you stuck both feet in your mouth, Thorsten. But let's continue.
<"R15 should be increased, will help the bass response and add "flesh" to the voices. Might first try a large value, say 220k and see if it is ok or is too full. If to full, then back off the value till it satisfies your tastes. "
Well does it? If we multiply 4700nF with 5.6 Kohm we get a 26,320uS timeconstant. This corresponds to a 6Hz -3db point, but because we have this whole thing attached to a bootstrap follower and not a normal cathode follower the actual -3db point is at 5.5Hz (per P-Spice which on such things is jolly close) and at 20Hz the LF rolloff is -0.3db (per P-Spice).">
Well, again showing your total lack of testing and experience. "A little low"? If you had actually checked, you would have found the time constant you mention cuts the bass dramatically vs a straightwire. Now add two more caps, and time constants, in this one tube stage alone, and you have a real problem with the bass.
Secondly, when the bass is cut, the mids thin out (washed out) and the amp can sound bright as well (also depends on the construction of the caps).
<"I think the "R15 is too low and hence thins out the bass" brainstorm can be safely put to rest.">
Of course Thorsten doesn't know what he is talking about as if he had done any basic/elementary testing of coupling designs, he would have found R15, C21 to be very weak in the bass region. Combine this with the two other coupling cap time constants and the plate circuit, and well...... Thorsten, you screwed up again as usual.
No wonder audio doesn't get any better.
<PS, the solution to the riddle of the bright sound?
The Velleman designer deliberatly loads this stage down to get a certain sonic effects by raising distortion, sadly doing it the way it is done here also leads to other sonic effects, namely usually a somewhat less than pleasant sound.>
Reducing the bass also thins the mids, lack of flesh type of sound.
<So, loads of points for effort positron, zero points for circuit analysis - my old tutors would so much have failed you in EE101, it is not even believable.>
Really? Interesting that my suggestions have fixed all the problems. I could have told you so and saved you alot of trouble.
And you got it wrong. And of course, you would have stuck with C18, but I am not going to quibble of that.
Hey, I thought you were telling me not to make major modifications!!! Yet what are you asking for, major mods??? Or nothing and leave James hanging?
And that I was calling his stuff **** (I was trying to be nice)? Yet you are cutting Jame's heart out. Why not do what you preach at me??
In conclusion, my suggestions were correct. If my advice were followed, James wouldn't have been hurt, the amp would have sounded better, and any minor tweeks could have been handled later, and Thorsten wouldn't have made a total fool out of himself again. Thanks Thorsten for all your trouble. It really helps audio.
Now just slink away in your shame.
moamps
Schematic below is from Rainer zur Linde's book "Build your own Audio Valve Amplifiers". WWW source is http://www.bonavolta.ch/hobby/en/audio/lindelin.htm
I have this book, measurements look good (-3dB at ca 30kHz, distortion below 0,1%), schematic looks very close to Thorsten's design.
Comments?
Kuei Yang Wang
Konnichiwa,
I amused myself a little bit more following the footprints of Positron. Very interesting. I can now understand why he is bitter. Well, a few more bit's of wisdom first....
http://java.audioasylum.com/cgi/m.m...+Steve&session=
"IDT triode (indirectly heated triodes )SETs offer broader frequency response without compromise than other SETs which are often +/- db which really means -db times two. Bass and highs more extended and more accurate. No hum problems a big plus because lower level nuances come through without hum masking. "
There are several claims rolled into this, the main thrust is (as usual) to suggest that DH Valves are technically inferior, we will soon see why this bothers Positron so much, but anyway...
The first claim is that depending upon the fact that a strean of supoposed electrons is emitted from a suitably doped metallic cathode sleeve or from a suitably coated wire we observe a difference in frequency response. Now here someone is getting desperate. How on earth can anyone in their right mind and with any even most basic level of electronic knowledge make such a gaffe? The frequency response is of course determined by the circuit design, not by the device itself.
The next claim is that using DH Valves invariably gives rise to hum.
Well I have build DHT Amplifiers with demonstrably and measurably < 0.2mV output noise without using extreme measures. That level of noise BTW being almost purely 50Hz from magnetic coupling into the Drivers anode load choke and nothing from the output Valve. Now 0.2mV is 83db below 1 Watt and on the specific Amplifier it would translate to 92db below nominal output.
I have build DHT Amplifiers where I took extreme measures and got the output noise to nothing but the drivers (5842) self noise, which made it difficult to see anything even with a sensitive 'scope.
So, DHT's cause hum? If you are an incompetent designer they sure do.
Let's move on to (mostly) character references for Positron. I'll let these speak mostly for themselves:
http://java.audioasylum.com/cgi/t.mpl?f=set&m=27217
"Before I even knew AA existed, I got an email of someone copying part of my webpage, and some crucifying it. That is how I found AA. I never criticized DHTs cause I didn't even know they were being used, let alon a big deal."
Hmm, at the time claimed 41 Years experience but never noticed DHT's.... Sure.
http://java.audioasylum.com/cgi/t.mpl?f=set&m=14313
"Well Tom. The impression I get is that me and others are idiots if we don't use DHTs."
"Then why was there a deliberate attempt at driving IDT people out of AA? I saw so much misinformation, propaganda and I have downloaded many of these postings. I saw so much harrassment against IDT owners, trying to squash any influence at AA."
http://java.audioasylum.com/cgi/m.m...ession=
Steve from SAS audio labs writes
"I can't even purchase transformers from one company, not that I want to now, because a DHT man blackballed my company, before I knew of AA or DHT company competitors. See where I am coming from? I was strictly trying to get a business going"
"But misleading, ignorance, or lying in a posting misleads, is close to fraud and just isn't right. All these horrible postings are phychological warefare."
jeff mai:
"I hope you aren't referring to our friendly exchanges, Steve. My specific dispute is with your claim that a triode connected KT88 has lower distortion than a 300B. I've repeatedly asked for proof of this and I'm still waiting. There is no lying, misleading or hate here; just a desire for the facts to be known."
"I actually measured it in a low distortion circuit. That is proof."
"It also seems to me that the so called "friendly" postings were not friendly but attacking my products."
"Another interesting point, BFS listed only my SE7.0W from 1999 in the review of the Edgarhorn slimline and not yours."
(Note - Jeff Mai is a DIY Enthusiast, no a manufacturer!!!!)
"SEE DAVE what I have been saying. Go back and look at how many postings where they said the KT88s had higher distortions than the 300b and 2A3s etc. There were several. I never posted first, just them. Yet it turns out my measurements from an actual distortion analyzer showed the KT88 to be lower. SEE DAVE what I mean. There is obviously bias and an adgenda here."
(Note - "SEE DAVE" is an appeal to the Moderator)
jeff mai:
"Disagreeing with you is an act of hate????? Asking for legitimate proof is an act of hate?????"
"What I do disagree with is your claim that a KT88 has lower distortion than a 300B. That's all; plain and simple. You offer the data on your web site as proof of your claim. By your own admission, this web site lists distortion figures for the WE300B that come from Western Electric's data sheets."
"This data was either measured or calculated for the 300B output tube in isolation. The data you provide for the KT88 is at the output of a complete amplifier. Because of this, comparison of these two pieces of data are not meaningful, i.e. you're comparing apples to oranges. For pointing this out, you accuse me of hatred and lies?????"
(Note - a common theme - as soon as someone disagrees with Steve he obviously is atticking him and his products and must by definition be a lier)
In another context further up the thread:
Steve from SAS audio labs writes:
"It is obvious some never wanted a good relationship with any IDT as it would hurt business. But blackball me from getting a certain brand output tranny is pretty sad. "
"Then the reviewer only heard the hum when he sat in his listening position, I believe 8 or 9 feet away. It was amazing how the postings in AA didn't even mention this and how those same postings were deleted when going into the archives."
mobile homeless writes:
"Lordy, Steve... Not quite sure what you are talking about here as it took me aproximately 15 seconds to find that amp and posts in question. Indeed, I was involved in the exchange and I dont remember anything deleted. In fact, if you look, Gordon even posts the name and location of the Neil Muncy paper concerning the grounding scheme."
"Gordon goes farther to admit it made for good reading and included some good ideas etc. He also discusses the perils of a piece of equipment going to Stereophile and how sometimes things dont turn out there as they were in your designers system. On the whole, that amp you are referring to received a GLOWING review.
(Note - So, who is lying?)
"Attacks that I was lying, cheating etc. And I didn't see more than one posting supporting the measurements and the truth. Just pure hate to try to discredit me."
Tom$ (Moderator IIRC) posts:
"The "untruthful attacks"? Are these the posts you obliquely refer to?"
"http://www.audioasylum.com/forums/set/messages/10249.html"
"http://www.audioasylum.com/forums/set/messages/10256.html"
"http://www.audioasylum.com/forums/set/messages/9989.html"
"Seems to me you just have a personal grudge against Jeff Mai, Rankin, and an unnamed person in an e-mail. Why attempt to damn AA as a whole if your beef is with 3-4 people?"
Dave VH (Moderator IIRC) posts:
"It is not the facts that have gotten you into this deep quagmire, but the way you handle people. Only you can control the way you interact with others, and I see no evidence that you are capable of diplomacy and tact. You seem to believe only in attacks and counterattacks, and as long as that happens, you will be engaged in perpetual ****ing contests."
"Me thinks that you should consider changing your strategy."
"I haven't seen anyone use the KT88 properly yet."
I'd also recommend to review the following threads as well. I think from the above and those threads the agenda becomes very clear.
http://www.diyaudio.com/forums/show...t304076
http://www.diyaudio.com/forums/show...d=26654
I have no conspiracy theories and I am in no conspiracy against the SAS Labs products, no matter what Positron thinks in his acute paranoia and alledges. I also do not suggest that Positron orchestrates a consistent campaign against DIY, DHT's and the like, far be it. I leave that to others.
Sayonara
Kuei Yang Wang
Konnichiwa,
To close of this whole positronic affair, a few closing remarks.
My considered opinion is simply that the man fell off the deep end when he noticed a lost opportunity to drum up busines and has now paineted himself into a corner wher ehe must continue to bash DHT's, DIY, people by far smarter and more experienced than he is.
And no - I'm not talking about myself (my experience with valve audio only goes back to the time I was around 8 or 9 Years old, an event only two years in the past as we have observed from Positrons postings) but people like Lynn Olson, Gordon Rankin and others whose fault it was to champion DIY and to suggest approaches Positron does not like.....
I do not think posting completely unprovoked comments like:
"I read the Lynn Olsen article for about the 4th time, and I would say some of it is utter nonsense. I would be careful about believing everything he says."
http://www.diyaudio.com/forums/show...t268877
sow either respect or consideration for others (any others) nor does it show particulary good ethics if what you are actually doing in effect is diss a competitor, a priori, without provocation and quite deliberate.
Oh, the later comments also show an appaling lack of experience and electronic knowledge, but that baby has been long poured out with the bathwater anyway.
Well, I shall call it as I see it. Sour Grapes, in my opinon.
Other people are sucessfull selling Amplifiers that he doesn't like to customers that he feels should rightfully be his customers. But according to him his rightfull customers are being misled by people like me via a concerted campaign of misinformation and hatred into buying DHT Amplifiers or (shock, dread) going the DIY route.
He appears to feel that this is costing him sales that are rightfully his. If so, why not sue? If you have a right to those peoples custom, sue the them for not buying from you, Steve! They can then sue people like me for giving bad advise after you won your case!
A quote again:
"See where I am coming from? I was strictly trying to get a business going"
Yes, I can see that. And still trying? No such thing as bad publicity?
My advise, stop arguing with others about why your products are so great and their own products (if they be such - remember, this is DIY Audio so few if any of the designs discussed are commercial), simply keep making them and if they are any good they will sell.
If not, well, as the Rabbi said to the Irish Catholic priest, "Life is short and Sh*t happens".
It is my considered opinion that Positron went way of the deep end and simply cannot handle reality. There are (mental health) professionals who can help, even in cases of extreme and unjustified paranoia like this one.
I do take his allegations of unethical behaviour on my part as very serious and will ask him here and now for PROOF that I have done any of the following:
1) Lied in any of my postings (he forgot to add "In my opinion" to "He lied", I do not give a nickel for his opinions, but he stated this as fact)
2) Misstated his posted texts (whatever position he may wish to convey is one thing, I have to go by what is written)
3) Directly attacked his company or products (as opposed to his views and opinions - such an attack would read "Amplifier XXX from Company YYY sounds bad because it uses Tetrodes - where XXX is his model and YYY is his company).
Well, on the other hand I might actually consider being singled out by Positron for the "third degree" a badge of Honour. At least I'm in excellent company.... ;-)
Sayonara
Kuei Yang Wang
Konnichiwa,
Comments?
The input Lowpass (Pot & R1 with C1) would seem to dominate the circuits upper cutof. I personally would likely prefer a little wider frequency response (closed loop) which can be achieved by reducing or omiting C1.
With C1 omited I'd expect the Circuit to have a very wide bandwidth, far past -3db @ 100kz which i normally consider easily good enough for human consumption.
Otherwise the parallels with the looped feedback, single stage design I suggested are obvious, similar design approaches are employed. The can also be found in old Citation preamp's, many DIY gear going back into the 1940's and the like. They are generally well understood and quite common. But anyway, I never claimed that the design was particulary special, it's more like "proven in the last 50 - 60 Years"....
Sayonara
Positron
Well, I see Thorsten not only had to use non- audio post but now into AA. Looks like you are the spiteful one.
The first section is about IDTs vs DHTs. Ok.
<The first claim is that depending upon the fact that a strean of supoposed electrons is emitted from a suitably doped metallic cathode sleeve or from a suitably coated wire we observe a difference in frequency response.>
Show me one of your amps with great FR. Back then I didn't see any amps with great FR. More drive required per watt output causes problems, one of which can be less FR. Capacitance problems also contribute. Didn't know this, ha?
< The frequency response is of course determined by the circuit design, not by the device itself. >
See above answer Thorsten.
<The next claim is that using DH Valves invariably gives rise to hum.>
Well, counting on no one else reading the post? If you had looked down a line or two you would have seen this, Thorsten:
"Well, if you have the hum problem solved good. I hope so. The reviews I have seen just don't seem to indicate the problem is solved".
<"Before I even knew AA existed, I got an email of someone copying part of my webpage, and some crucifying it. That is how I found AA. I never criticized DHTs cause I didn't even know they were being used, let alon a big deal."
Hmm, at the time claimed 41 Years experience but never noticed DHT's.... Sure.">
I was working on my designs, and only subscribed in 1980 to Audio for 1 year. Didn't even get my webpage up till Dec, 1996. Peoria, and surrounding area doesn't have a high end store.
By the way, I am not the one changing his story about being heavily involved in tubes for only approx 2 years. How did you test all the circuits during this time? And how did you get all the money to purchase these parts and designs when you were rather tight on money? Did someone give you all these parts, or just make some assumptions?
And I am not the one who admitted he was getting compensation under the table? Only test Transformers and whole sale prices on components? You stated customers weren't paying you, but you didn't state if you are getting money from the dealers, wholesalers, manufacturers, or anyone else. Are you getting kickbacks, either monetarily or non monetarily?
<"Well Tom. The impression I get is that me and others are idiots if we don't use DHTs.">
I am not the only one who had problems. Decware also seemed too. In fact, Decware had it out with about 9 or 10 of you guys. Aren't you a poster at AA?
< I can't even purchase transformers from one company, not that I want to now, because a DHT man blackballed my company, before I knew of AA or DHT company competitors. See where I am coming from? I was strictly trying to get a business going"
"But misleading, ignorance, or lying in a posting misleads, is close to fraud and just isn't right. All these horrible postings are phychological warefare.">
Well, I got a catalog from them and all of a sudden, I couldn't purchase or get any info from them. Just bad luck I guess? The company didn't go under.
<"It also seems to me that the so called "friendly" postings were not friendly but attacking my products.">
Of course you didn't post the previous postings did you. How convient.
<Note - Jeff Mai is a DIY Enthusiast, no a manufacturer!!!!>
Of course a half truth is the same as a lie Thorsten. Where are his other posts to explain what he was doing?
<SEE DAVE what I have been saying. Go back and look at how many postings where they said the KT88s had higher distortions than the 300b and 2A3s etc. There were several. I never posted first, just them. Yet it turns out my measurements from an actual distortion analyzer showed the KT88 to be lower. SEE DAVE what I mean. There is obviously bias and an adgenda here.">
Remember Thorsten, you tried this same tatic mentioning a test. (notice he capitalized words too) As I recall the test you and others use as reference was a WE 300b vs a Chinese KT90. The best vs the worst. Why not the best vs the best?
<Disagreeing with you is an act of hate????? Asking for legitimate proof is an act of hate?????""
And what about the posts you skipped over again Thorsten?
<"This data was either measured or calculated for the 300B output tube in isolation. The data you provide for the KT88 is at the output of a complete amplifier. Because of this, comparison of these two pieces of data are not meaningful, i.e. you're comparing apples to oranges. For pointing this out, you accuse me of hatred and lies?????">
But if you had bothered to post how I tested, but conveniently skipped over again Thorsten.
I used a special, virtually no distortion signal generator plus one special stage with near zero distortion to drive the output tube and OPT to measure the distortion, hardly the whole amp.
Also, in other posts, which Thorsten again doesn't mention, they mention they used only calculations off of paper curves. Being off only 2ma (which would be good) could add .5%, 1% or more distortion. Hardly accurate compared to actual measurements.
<"Lordy, Steve... Not quite sure what you are talking about here as it took me aproximately 15 seconds to find that amp and posts in question. Indeed, I was involved in the exchange and I dont remember anything deleted. In fact, if you look, Gordon even posts the name and location of the Neil Muncy paper concerning the grounding scheme."
"Gordon goes farther to admit it made for good reading and included some good ideas etc. He also discusses the perils of a piece of equipment going to Stereophile and how sometimes things dont turn out there as they were in your designers system. On the whole, that amp you are referring to received a GLOWING review.">
A couple of problems Thorsten.
First, how many posts were posted before mine, and how long?
Is his posts in the same string?
Second, The maufacturer posted after I brought up the hum problem, is that what you are saying?
And how much time elapsed before he posted?
And was anything brought up about the replacement of output tubes needed? Because the reviewer had to try 3 sets of tubes to get it working properly. And the manufacturer, if I remember correctly, stated somewhat later, in another string on AA that the tubes were ok. So any EE could have figured what was happening. But he must have posted much later cause I don't remember his post.
By the way, I have several witnesses who have seen postings deleted at AA. In fact, according to one witness (A), Rod called <A> and mentioned he was investigating one of his guys (B) after <A>s post was deleted, a post recommending my 10A preamp (someone requested a good preamp and many brands were recommended). Another witness to (A)s post contacted me stating (B) contacted him and said Rod may have laccidentally deleted (A)s post during some work. So the post was there. Of course, (B) no longer moderates at AA. If one can delete, one can also altar one too, maybe even add.
<Tom$ (Moderator IIRC) posts:
"Seems to me you just have a personal grudge against Jeff Mai, Rankin, and an unnamed person in an e-mail. Why attempt to damn AA as a whole if your beef is with 3-4 people?"?>
Interesting, cause I believe Tom was the one under investigation by Rod for deleting (A) post. Afterall, I believe, Tom posted he was the only one besides Rod to run the chat program. Either way, Tom posted several, (A)s post never existed, as I recall, yet indicated to this witness that it was posted.
By the way, read one of, if not the last post of Decware on AA. I believe he addresses 9 or 10 people, not 3-4 that is mentioned. So something is very wrong with the post you referenced.
<"It is not the facts that have gotten you into this deep quagmire, but the way you handle people. Only you can control the way you interact with others, and I see no evidence that you are capable of diplomacy and tact. You seem to believe only in attacks and counterattacks, and as long as that happens, you will be engaged in perpetual ****ing contests."
"Me thinks that you should consider changing your strategy.">
Interesting since 9-10, or more who were attacking me were also attacking Decware. And remember I didn't even know AA existed or wanted to post until someone copied and they started attacked my webpage and use of tubes. So why didn't they use diplomacy??
By the way, in one string I was accused of bringing up a subject, when the original 1st individual again posted below me, and stated he started the subject. You guessed it, that first post he made was deleted. That is honesty isn't it.
Let's continue on.
<I have no conspiracy theories and I am in no conspiracy against the SAS Labs products, no matter what Positron thinks in his acute paranoia and alledges. I also do not suggest that Positron orchestrates a consistent campaign against DIY, DHT's and the like, far be it. I leave that to others.>
Interesting since Thorsten used a non audio post and went to great lengths to retrieve postings from AA. I haven't responded in kind. I simply replied to his latest attacks on me.
You don't accept payment from customers. However, for the record, do You take payments from Dealers, Distributors, Manufacturers, or anyone else, monetarily, or non monetarily?
And no I am not trying to boost business. I just hate to see someone seemingly "scalping" money from others. I would much rather use Frank's designs than Thorsten's. That is a tip to the newbies.
By the way, I openly expressed my owning an audio company. But if someone feels I have an adgenda, no problem. But at least I have been completely open concerning this matter.
Positron
There isn't much here to reply too. Personal attacks from Thorsten who has had to retrieve non audio posts, and posts from another chat site. I haven't returned in kind. Sounds like you are the one who is bitter.
Any comments I have made about Mr. Olson's article are fro
