diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
choke winding - Click HERE for Original Thread
Tim Wyatt
I am wanting to wind my own 10H choke. Any good info on the web as far as gauge and number of turns ect that you know of? Thanks.
Sherman
Try this-
http://lalena.com/audio/calculator/inductor/
audiobot
Hi Tim,
I've been thinking about trying this too. Just sort of practice to trying output transformers. There is a good section in RDH4 that walks you through all of the calculations. I don't remember any good web sources, but will check some of my links.
Sherman-That calculator is for an air core inductor not an iron core choke. Good for RF or speaker crossovers, not so good for filter chokes.
Michael
Tim Wyatt
quote:
Michael
I wonderd why I was coming up with a 15 pound monster choke
Fuling
If a german link i OK, have a look at this page:
http://www.jogis-roehrenbude.de/
Scroll the sidebar all the way down (almost)
tom1356
Are there any guidelines or calculators for winding fine silver wire chokes or inductors?
Sch3mat1c
Silver is almost the exact same as copper except for color and price. Nothing changes, except maybe a slight increase in current capacity. Much more benefit using say, GOSS as opposed to a NOSS core.
Hey Tim, I'd go with 2 or 3000 turns of wire adequate for the current draw, on a gapped core of sufficient size to hold the wire. You can use SWAG's to find such things as winding area needed, based on turns and wire diameter. I happen to have a table for all those figures though. :D
If it's for a pi filter, you can space (random) wind, just put the wire on evenly in semi-layers. If choke input, you'll need to wind even layers and insulate between each with a strip of plastic or paper.
Tim
fdegrove
If you use silver wire as hook-up wire etc. in your system it does make alot of sense to use it throughout.
Cheers,;)
Page generated in 0.024198055267334 seconds with 17 queries,
spending 0.00663137 doing MySQL queries and 0.01756668 doing PHP things.
Please support our sponsor.
