diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
cathode connection in directly heated triodes - Click HERE for Original Thread
metebalci
Cathode circuit is connected to the point half in between the heater pins of directly heated triodes (such as 300B). I think this is to eliminate hum by connecting +Vh/2 to one and -Vh/2 to the other pin. Is it right ?
Is such a connection necessary if triode is heated with a DC supply ? will simply connecting the Vh (+) supply to one and cathode circuit to other pin of triode work ?
Thanks in advance.
MB
Sch3mat1c
Right on both counts. In fact tube data is traced with DC heaters and ground connected to a specific pin. I forget which though.
Tim
metebalci
Thank you so much...
MB
Page generated in 0.017035961151123 seconds with 16 queries,
spending 0.00776505 doing MySQL queries and 0.00927091 doing PHP things.
