diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
211 Preamp - Click HERE for Original Thread
hacknet
i`ve heard of a couple of people enjoying a 211 as a preamp. but, i can`t seem to find any 211 preamp schmatics online.
any one know any?
looking at the datasheet, the 211 seems to have a rather high plate resistance. is this okay for preamp without an output transformer?
analog_sa
Not unless it's used as a cathode follower
hacknet
well, i`m not a great fan of cathode followers. i`ve found them dry compared to a plate follower.:)
analog_sa
So have I. But it's a simple choice - follower or transformer unless you want a huge pre that can't drive anything.
hacknet
hmm.. thats kinda ****...
in this case, can anyone recommend a tube i can impliment in a simple manner which is generally know for its dynamics and drive?
i`m using a 6900 now and it seems okay. i`m just looking for something more...;)
Roscoe Primrose
quote:
The 211 has a relatively high plate resistance for a power tube, but it's still lower than many of the tubes people like to use for pre-amps, including the 6SN7. Of course, to get the 211 up to a plate voltage/current where it's going to be happy will pretty much force the use of choke loading or the B+ will need to be in the several kV range :bigeyes:
Peace
hacknet
i was actually thinking of a 100H choke load.
slowmotion
Hi hacknet, all
I used to have a chokeloaded 300b as output buffer in my linestage,
sounded ok, very "organic" sound ;)
cheers ;)
hacknet
wow, okay...
would you attribute the organic sound to the 300b or the choke load?
i`ve heard much about choke loads but i`ve never tried... i think i`ll do so soon;)
analog_sa
You owe it to yourself before embarking on adventurous high-voltage 211 plans. Choke loading sounds better than any resistor to my ears - more dynamics, better rhythmically, a more interesting sound in general. Just decide upon current and inductance and get on of Lundahl's plate chokes from Martin Electronics - you don't really need to buy expensive chokes to get great sound.
slowmotion
quote:
Probably a combination....
cheers ;)
hacknet
hmm.. i`ll put that top of my list to get a pair of chokes...
analog_sa: wow, you know martin:cool: okay... i actually have a custom trafo winder in mind.
whats to keep in mind when picking a choke other than current capabilities? any special cores to look out for?
BTW, how do you determind the required inductance?
is it through the reactance of a choke to ac at the lowest freqency i want to achieve?
analog_sa
Exactly. So this reactance may be sufficient for a low Rp tube but not for a high Rp.
Nickel content is always good. Not so essential as for interstage transformer but still desirable. Your winder presumably has experience with plate choke winding geometry and knows how to achieve low parasitic capacitance. I mostly use two Lundahl chokes - 1667 and 1668 and between them they cover a large variety of possible tubes. A good friend of mine compared my Lundahls to his Bartollucis and couldn't qiote decide which was better.
hacknet
hmm.. okay.. thanks..:cool:
any one put a choke at the cathode and used it in a cathode follower?
Page generated in 0.03571605682373 seconds with 17 queries,
spending 0.00863624 doing MySQL queries and 0.02707982 doing PHP things.
Please support our sponsor.
