diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
6.3v 30A!? - Click HERE for Original Thread
imix500
Anyone know a source for a large (~30A) 6.3v filament transformer? Thanks!
imix500
Surplus would be prefered, of course.:)
Sch3mat1c
e-Bay, control transformers, uhm what else...
Tim
jackinnj
try Electronics Surplus in Cleveland OH
Tom Bavis
Where are you in NY? 12V@16A I can do...
imix500
Actually in Jersey just north of Hoboken, but closer to the city than some parts of the city.
Alastair E
How about a modded PSU from a computer?
These have high current DC 5v supplies, if modded could be run at 6.3 possibly......
hacknet
i think you would have to re design the whole Com SMPS.
most don`t an output capability anywhere near 6.3v.
well, i saw a 7.2v 35ampere SMPS at a surplus shop the day before. i wonder if you can find this sorta things where you reside.
Tensop
you can usualy get 6.3v out of a comp psu by adjusting the duty cycle
their current output would range from 15 amps to 50 amps, depending on brand and such :)
hacknet
problem being that the smoothing caps are all rated 6.3v. i wonder if it is possible to increase the voltage with the turn of a simple pot?
Sch3mat1c
Aww heck, they won't mind.
Tim
imix500
Yeeeah, electrolytics have a 10% tolerance right?
I looked into switchers, they're cheap and some are adjustable, but most are only good for about 10% more voltage. 5.5v is close, but not quite enough.
Sch3mat1c
At the low load you'll be running, I wonder if it'll even mind the lower emission.
Tim
imix500
Hmm, that may be true. Are there any tell tale signs that a hydrogen thyratron is unhappy if the volatge turns out to be to low? Thanks!
Page generated in 0.25843906402588 seconds with 16 queries,
spending 0.18332696 doing MySQL queries and 0.07511210 doing PHP things.
