diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Grounding question regarding an active crossover - Click HERE for Original Thread
Alcaid
Is it important to keep seperate power- and signal-grounds and then connect them together at a single point, or can you just ground randomly in an active crossover?
tiroth
I used one signal star ground and one power star ground per PCB (HP or LP channel) and then ran these all back to the power supply.
Alcaid
Was it a double sided PCB or a single sided? Have you got a picture of it (traces and component-overlay)
Page generated in 0.016007900238037 seconds with 17 queries,
spending 0.00755477 doing MySQL queries and 0.00845313 doing PHP things.
