diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
Wiring a 12au7 - Click HERE for Original Thread
A3rd.Zero
I am using a 12au7 in a preamp and I have questions about wiring it to the 6.3volt supply. I have heard that you can use a 12au7 on a 6.3volt supply somewhere but I cant figure it out. Unfortunatly I only have one 6.3volt winding on my transformer so I may be out of luck. Can anyone tell me how to do this?
Milo
Sch3mat1c
Tie pins 4 & 5 together, connect 6.3V across pins 4+5 and 9. Just connecting both halves in parallel.
Tim
A3rd.Zero
Sweet. Thank you very much. I had thought for a moment that I had screwed the pooch big time.
Milo
A3rd.Zero
Hang on. Isn't that the way you would wire any tube that takes 6.3V to a 6.3V supply (Ie a 6Dj8)? The 12Au7 is a 12.6V tube though.
I am sorry if I'm beting an idiot, Im still getting the hang of this stuff.
Thanks for your help.
Milo
SY
Milo, no, you hook up a 6DJ8 by running 6.3 v between pins 4 and 5. They're not tied together in that case. Pin 9 in that family isn't a heater center-tap, it's usually a shield.
A3rd.Zero
So what should I do with the 9pin on a 6DJ8 tube? leave it alone or ground it? Thanks for your help, I really appreciate it.
Milo
SY
In most cases, just leave it alone.
A3rd.Zero
Thank you Sch3mat1c
Thank you SY
I think I can build my amp now. mmmmmmmm, tube amp :P
milo
s2kov
quote:
Tim
How about connecting both halves in parallel if you have 6.3V Center Tapped (3.25-0-3.25)? Where do you think i can connect Pin 9?
Thanks....
cogsncogs
s2Kov,
Like this.
Wayne
s2kov
quote:
Thanks....
Thanks wayne....
s2kov
Guys,
In addition to my previous question, assuming i use to two (2) 12au7 and both halves connected in parallel. What is the required current for the transformer? Is it 0.6A for two twin triode?
Thanks....
s2kov
Anyone????
Thanks wayne....
Sch3mat1c
Each heater half uses 6.3V at .15A. Add it up.
Tim
s2kov
Thanks Tim.
Appreciate your help....
Anyone????
Page generated in 0.033696889877319 seconds with 17 queries,
spending 0.00877380 doing MySQL queries and 0.02492309 doing PHP things.
Please support our sponsor.
