diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
5687 - Click HERE for Original Thread
Alastair E
Can anyone recommend an Octal upgrade / equivalent for the ever popular 5687, maybe with a higher Ia
It will be used for the dirver stage in an OTL, running 8xEL509
I would like to use an octal bottle rather than the B9a
Thanks!
fdegrove
ECC99, 12BH7A for noval types.
As far as octals go, I don't know of any twin triode of the top of my head but the dissimilar triodes may be a good idea; 6EA7, 6EM7 etc.
Cheers,;)
filippo22
search for some twin triode computer grade like the 6414 or 6350, the new ECC99 is also a good choice, but they are all 9pin base. If you need an octal base maybe you can use both triode of the old 6SN7GTA or the twin dissimilar triode mentioned above. Maybe also the 6BM8 in triode mode with a choke load is good for drive an OTL.
ciao
Filippo
www.audiofanatic.it
PS a 6922 version of the Supertotem is now on-line on www.audiofanatic.it
i_should_coco
How about 6BL7/6BX7? They're pretty good as drivers.
Cheers/
Pete
Alastair E
looked at the 'BL7, it could be a good performer, bit hard to come by, I geuss Ill have to search harder!!
fdegrove
The BX7 is much better and will probably cost just as much anyway.
Cheers,;)
Alastair E
I read somewhere the BX has different specs for each triode section, I was hoping to use one for each set of o/p valves, or even strap them together for lower impedance
Al
fdegrove
No, both are twin triodes.
Cheers,;)
Page generated in 0.02827000617981 seconds with 17 queries,
spending 0.00906110 doing MySQL queries and 0.01920891 doing PHP things.
Please support our sponsor.
