diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
Copper coil inductor vs. round core inductor - Click HERE for Original Thread
tomchaoda
If cost is not an issue, what's the pro and con of using copper coil inductor in the L part of a pi-filter, when compare to a regular round core inductor?
Thanks,
Thomas
Nelson Pass
Do you mean air core vs something with a core?
tomchaoda
quote:
Yes, the air core (round core wire) vs. the copper foil (flat foil type). What's the pro and con of both?
http://www.partsexpress.com/aircoreinductorpage.html
vs.
http://www.partsexpress.com/copperfoil.html
Thanks,
Thomas
Nelson Pass
Obviously the ones with cores have lower resistance. An
inductor on the order of 2 mH witha big iron core is good to
5 or 6 amps DC in my experience before it starts saturating and
losing inductance. The air cores don't saturate, but they can
get pretty hot unless the wire is really thick, like 12 Gauge.
I'm not really certain about the advantage that foil is supposed
to give, particularly if they're just being used as power supply
filter chokes. They look good, though.
Pjotr
The flat foil coils have simply lower losses. They have lower DC resistance and due the relative thin conductor the skin-effect is lower. They have advantages for a mid-high x-over but if they really make your speakers sound better …
tomchaoda
Nelson and Pjotr:
Great info. THanks!
Thomas
promitheus
The copper foil ones have less losses and very thick cross section. They cost though a lot more.
Page generated in 0.022097110748291 seconds with 17 queries,
spending 0.00703120 doing MySQL queries and 0.01506591 doing PHP things.
