diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
need pinouts for infocus smartview 3600 video - Click HERE for Original Thread
lostsoulman
I'm looking for the pinouts for the 26pin video connector or the wiring list for the video cable to connect the 3600 to my computer.
I only have the LCD panel, no power supply or remote.
I have it powered up with bench supplies and have the audio and video from a VCR as an input. Seems to work ok. Now I need any other info on the remote and video from a computer. If one of the replacement remotes will work, please let me know. Also if someone can send me a captured remote output that would work too.
Thanks for any help.
msx-2
the schematic here should work
http://www.diyaudio.com/forums/show...8891&highlight=
webtelles
Hi Lostsoulman,
Can you tell me how did u power it on ? What kind of power supply did u use? I have one here that says 12v 8A and other with 5A output, Im scared about burn it.
I just got one, and I have no cables.
Thak you
gregory27
If you buy one, buy one with power, and video
my favorite panels are
Sharp qa 1200, 1400, 1500(awesome color on these)
Ask panels are nice if high enough color and resolution
Proxima are also very nice.
Make sure you see a picture, or it doesn't say AS IS, because there are some that will sell non working panels.
unless you can solder awesome, then make your own cable, i tried and couldn't do it, had to have my friend make it for me
good luck!:smash:
Page generated in 0.023375988006592 seconds with 17 queries,
spending 0.00779557 doing MySQL queries and 0.01558042 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
