diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
grounding question - Click HERE for Original Thread
skyraider
hi guys,
i need advice here. I often heard 'power ground' and 'signal ground'. What does it means? I usually just ground everything to a single point. I thought ground is just a sink for all the currents to flow? Why is there two ground points?
thanks!
Ropie
This is a very well covered point, but two grounds are used to separate the signal current from the power source. The two grounds are then linked together (with a thin wire to help prevent the larger power current flowing back and infecting the signal ground).
Most people building gainclones use two grounds per channel as the power star ground should be placed as close to the 1000uF caps as is humanly possible, as this keeps the signal path short and makes for a better sounding amp.
Look at any schematic for details of which point to connect to which of the two grounds.
Page generated in 0.019934892654419 seconds with 17 queries,
spending 0.00996184 doing MySQL queries and 0.00997305 doing PHP things.
Please support our sponsor.
