diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Peter Daniel What type of fasteners are those? - Click HERE for Original Thread
PHilgeman
That you use on all of your chassis. It looks like a countersunk washer that you can use in order to get some flexibility by drilling your holes a bit larger. Into the countersunk washer fits you cool screw.
Where do you get those? I would be very interested in buying the washers alone for some size 8 counter-sunk screws.
Thank you,
Paul Hilgeman
Peter Daniel
It is a high tolerance brass bushing with 0.25 inside hole and 0.50 mounting hole. It accepts shallow counersink screws.
I don't use them much, mostly in the preamp, but I'm running out of them quickly. They come form aircraft industry and I would be interested myself, where to source more of those.;)
Dark Shadow
You might http://www.interfast.ca
Cheer,
Francois.
Dark Shadow
I can supply you some Hi-Lite 5/32 and 3/16 if you have a impact gun =)
Peter Daniel
Of course, I have impact guns. I even have an offset collar installation tool (by Atlas) ;)
And I have some local friends who currently work in the industry, but I'm always on a lookout for nice fasteners.
I somehow never thought about using Hi-Lites in chassis building, but maybe it's something to think about. I used rivets recently, and I'm very satisfied with results.
They are not sqeezed too tight, I made counersink for lower manufactured head size ;)
Dark Shadow
Let me know if you want some, I will make you a good price but without any tracability (That the reason I'm able to sell it =)).
I will check the quantity I have in stock.
Peter Daniel
Here's the other side. It will be sanded. so the rivets would be barely visible.
Dark Shadow
Why don't you just shave it? will give a even better finish no? That what we do here on Bombardier wing plank when we install interference fit freeze bushing to repair some damaged holes.
Coulomb
If you use a Dewalt Pilot drill after you drill with a standard drill for the rivet hole, you will get a nice little ledge to catch the Rivet head and have it flush to the material surface.
Anthony
Peter Daniel
Micro shaver is about the only tool I don't have;), but the aluminum parts have to be brushed and sanded anyway (for better appearance).
Peter Daniel
quote:
We prefer to use more advanced tools;)
BTW, the list price of that pistol drill gun is close to $1K, if not more.
Dark Shadow
Check on ebay, there very cheap. I got two (one zephir and one magnavon) and 10 countersink bits for 10$US+transport.
Here one:
http://cgi.ebay.ca/ws/eBayISAPI.dll...&category=25259
and here one with shaver bits:
Dark Shadow
BTW, list price for that pistol drill gun is close to $1K, if not more.
As I see you already have a microstop =) You only need the shaver bit =)
Peter Daniel
Actually, I was thinking about complete gun, they make them really nice and small. It is still $500 though;)
Dark Shadow
=) Yeah, but for my usage I would only buy a shaver bit. I don't need a other gun or the stabiliser. I don't shave enought rivet to make this kind of expense. =)
Peter Daniel
I find yardstore.com to be a very good and competetive supplier of tooling and accesories (both new and used)
http://www.yardstore.com/
Dark Shadow
Anyone interrested to buy some Hi-lite: HST10AG5 with the nuts?
15$US for a pack of 50 with the nuts + shipping. What do you think?
Dark Shadow
Here is some specification on the Hi-lite:
Material: 6AL-4V Titanium Alloys per Spec. AMS4928 or AMS4967
Heat Treat: 95,000 PSI Shear minimum
Here the complete specification
http://www.hi-shear.com/standards/hst10.pdf
Page generated in 0.043751001358032 seconds with 17 queries,
spending 0.00804949 doing MySQL queries and 0.03570151 doing PHP things.
