diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Musical Instruments
Tube Effects - Click HERE for Original Thread
guitargully
Hey everyone,
Yesterday I got a tube distortion box from my friend to borrow for a while, well.. it wasnt working and i told him i'd fix it.. so i took it home, found a few loose wires.. etc. and fixed it. I really like the sound of it- it has a nice warm distortion sound with alot of tone, somthing i cant get with the SS effects in my Crate head. Anyone know of some designs i could use to make one? I'd like to use an off-the-shelf transformer.. and no chips.. there's an easy looking design on www.generalguitargadgets.com , but it uses a JRC4558 chip.. i have the feeling that does more work than the tube. The one on that sight uses a regular old 12V transformer.. so it would be nice if i could use somthing similar. Thanks.
Centauri
I assume you are referring to the "tube driver" project. This is nearly identical to the Dean Markley "Overlord" pedal, and this sounds very good. The op-amp is only used as a convenient way of increasing the signal level to the tube - the tube does all the overdrive work. It would be possible to replace the chip with another 12AX7, however it becomes more difficult to fit it in a small space.
Cheers
Page generated in 0.017638921737671 seconds with 17 queries,
spending 0.00804043 doing MySQL queries and 0.00959849 doing PHP things.
