diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Crystal Conundrum - Click HERE for Original Thread
5th element
When a manufacturer specifies a load capacitance what exactly does this mean.
I know that you connect two capacitors from the crystal legs to ground. But if they state a value of 30pf does that mean use two 15pf or two 30 pf?
The data sheets for the make ive found are useless.
Cheers Matt
5th element
Someone? Anyone?
GaryB
It means the effective capacitance across the crystal. For the case you mention where you want a 30pf load, then you need to remember that the two capacitor to ground are effectively in series. To get a 30pf load would require a 60pf cap to ground from each leg.
Of course you also need to consider the capacitance provided by the rest of the circuit and adjust accordingly. More capacitance will pull the frequency slightly higher.
---Gary
Page generated in 0.025002956390381 seconds with 16 queries,
spending 0.00954771 doing MySQL queries and 0.01545525 doing PHP things.
Please support our sponsor.
