diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
Help with Zen Headphone Amp - hiss... - Click HERE for Original Thread
batee
Built Marcello's headphone amp last evening. Sounds great except for a faint hiss (sounds like white noise).
Details:
Measures about 5mVPP at the output terminals when connected to paused source (a Sony DVD player) measuring 0mVPP.
Sony 75 Ohm headphones.
Don't have it in an enclosure yet - part's on the truck. Did connect ckt ground to line ground via 100 Ohm resistor.
Noise disappears when I short the input terminals of the amp boards.
Amplitude is constant regardless of bias settings or source level.
Used a few cheap (RS) carbon comp resistors in non-power situations (I live in a small town).
FETs matched to 300uV.
Thanks in advance for any assistance,
Bryan A. Thompson
batee@roadslessphotographed.com
Nat Riscica
Hello Batee,
I have had the same problem. I solve it by adding a o.oo1 ceramic capacitor across the base-collector of the ztx 450 like the original Zen schematic.:D
Nat Riscica
Page generated in 0.081763982772827 seconds with 17 queries,
spending 0.04894662 doing MySQL queries and 0.03281736 doing PHP things.
