diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
TWINS!!! Zen v4 - Click HERE for Original Thread
Super_BQ
It's ALIVE!!!
http://www.geocities.com/lelamjade/ZEN4.html
Comments please before I submit. Hope it's well enough for the Pass Gallery.
BQ
PS: Sorry if Geoshities limits the the bandwidth..
Mark A. Gulbrandsen
Dang,
They're as long as the Lord Of The Rings Trilogy:eek: !
Beautiful job!!!
Mark
moe29
very versitile!
but i can understand running them balanced most of the time.
very sweet :)
Blues
The look of your Zv4 reminds me of Plinius, also of NZ.
Great job! When you lift 'em, are you sure your wingspan can span the amps depth?:)
Panelhead
quote:
Originally posted by Super_BQ
It's ALIVE!!!
BQ
Great Job! You should qualify easily.
George
Nelson Pass
Somebody finally understands what I mean by
Lots of Heat Sink! :cool:
stefanobilliani
:smash: Very well done ,
I am glad that you like balanced mode , and for sure you have also a lot o power avaiable .
Congratulations for a good work.:D
Super_BQ
Thanks everyone for your kind words!
Will be looking at a plexiglass (perspect) cover for the twins later this week and a final submit.
BQ
Audiofanatic
This is what I call cooling down a nice hot amp!
Congrats BQ.
I hope they sound as good as they look!
Audiofanatic ;)
rebojorge
nice work!..... what kind of speakers are you using?
Super_BQ
rebojorge,
Currently using some cheap bookshelf like speakers. I have a brand new still in the box Klipschorns that I won't hear until the new house is finished - sometime next year.
BQ
thylantyr
:cool:
BobEllis
Hey, if they published my A75, you are in like Flynn. Nice work.
Question: Do you get much heat transfer to the front/rear heat sinks? It looks like your side walls are 3 mm or so. Is that enough to keep all sinks roughly the same temp?
Super_BQ
Bob,
The heat is primarily from the middle. When I built my old SoZ, I had the transistors on the very back which not only heated the rear heatsinks but also the front ones quite well. The middle portion was considerably cooler. What was going on? My thoughts was the hot air was moving faster in the middle of the chassis than the front and rear heatsinks. So in the Zen 4, I tried to take advantage of this convection cooling.
I should also say that when I ran the amps balanced, my cdp has balanced outputs and the Bride of SOZ preamp was also in balanced. - these may have been a big influence on the sound of the Zen 4. In my singled ended testing, I used the same CD player and same pre-amp.
BQ
JC Fardo
Hello BQ
Nice job and thanks for share your projects in your page.
By your pics I canīt figure how you had integrate three sinks per side. What you describe is tipical residual insulation between sinks interface IMHO.
I can suggest you to install a bolted copper plate 3 or 6mm thick with total area of all 3 sinks w/ usual heat grease and attach the mosfets to this copper plate. This can improve heat conduction in a uniform fashion. Yet not 100% as desirable.
HS HS HS
>I I I I<>I I I I<>I I I I<
C O P P E R P L A T E
P C B
Also I suspect that amp cases are too small to make air convection efective.
Sorry for bad english and hope this helps
JC
Page generated in 0.033211946487427 seconds with 17 queries,
spending 0.00797248 doing MySQL queries and 0.02523947 doing PHP things.
Copyright Đ1999-2008 diyAudio.com
