diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Subwoofers
Tools for subwoofer - Click HERE for Original Thread
Andre Baptiste
Hey dumb question c an i build a sub...with a jigsaw alone?
random_id
Sure.
You can do anything you want...and a jigsaw is a great "anything" saw. To make things easier, you might want to try using Sonotube. Then you will only need to cut two plywood/MDF circles to cap on the ends.:D
BobEllis
That's how I did my first.
However, it is difficult to get straight, square cuts with most jigsaws. Even a throwaway $40 circular saw guided against a straightedge will get better results - less filler needed, less frustration. Or you could use a router and 1/4" straight bit against a straightedge, then you'd have the right tool for teh driver cutout. With inexpensive/low power toold just remember that you need to take shallow cuts and go fairly slow. My $50 Craftsaman router lasted therough many sets of speakers and other jobs before the bearings gave out. It is still Ok for rough work, 15 years later.
454Casull
Doesn't Craftsman have a lifetime warranty?
Drew Eckhardt
quote:
Only on their hand tools.
Page generated in 0.020584106445312 seconds with 17 queries,
spending 0.00782108 doing MySQL queries and 0.01276302 doing PHP things.
Please support our sponsor.
