diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
Do I need a LPF? - Click HERE for Original Thread
Dxvideo
Hi all,
I want to build a simple 5.1 gainclone with 2 TDA7370s... Each channel (except subwoofer) will be 7W (%10THD) and sub will be 24W. That gc will be used for a cheap DVD's analog 5.1 output.
The question is; do I need a low pass filter and/or a preamplifier for subwoofer input?
Thanks for your interest in advance..
abid_rehan
Well I guess in such a case you wont be needing a LPF as DVD's analogue out at subwoofer has already LPF.
matjans
it does have a LPF but often it's filtered way to high...
I used a passive 100Hz LPF and that sounds way better...
Dxvideo
Thank you very much.... I will finish the project in this week. The main problem is volume control... I guess I will use four seperated pot..
macboy
For volume control, try the National LM1036. This IC controls the volume, bass, treble, and balance of 2 channels using DC voltages to control each of those parameters. You can use three of them for 6 channels, using the same voltage to to control the volume on all of them. This chip will add a very small amount of distortion, but it doesn't seem like you are shooting for stellar sound quality to begin with.
Page generated in 0.021759033203125 seconds with 17 queries,
spending 0.00872898 doing MySQL queries and 0.01303005 doing PHP things.
Please support our sponsor.
